No Brake lights, Not getting power to brake light switch |
tmaney |
Mar 27 2006, 11:43 AM
Newbie Group: Members Posts: 15 Joined: 22-July 03 From: Northern Virginia Member No.: 932 Region Association: MidAtlantic Region |
I am going through a wiring diagram, but was hoping that there might be someone else out there that has had this problem.
I lost my brake lights a few weeks ago. Bulbs good, power to taillights. I have a new brake light switch that is/was working, and seems to check out with a multi meter. I dont think that I need a new one, and don't seem to have a problem at fuse number 8 location. Anyone had any luck tracing a wiring problem for the brake lights? |
1970 Neun vierzehn |
Mar 27 2006, 06:15 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
tm,
Check the electrical connections/contacts at the brake light switch by the pedal assembly. U want clean and tight connects. Hope that helps! |
john rogers |
Mar 27 2006, 06:41 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
The wires are black with yellow stripe so check to make sure the connection at the fuse panel is good and tight with 12.5 volts. On both our 73 and 74 the key has to be fully on before they will work. With the switch unhooked make sure the wire connector(s) at the brake lights do not show a short to ground. Finally with the switch on make sure one of the black/yellow wires shows 12.5 volts at the switch connector. Good luck
tmaney |
Mar 28 2006, 08:06 AM
Thanks John, havent tried that and it sounds like the best way to proceed.
Lo-Fi Version | Time is now: 17th May 2024 - 08:52 PM |
