speedo in need of exorcism..... |
scottb |
Feb 20 2003, 04:37 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
speedo is behaving an a strange manner. bouncing between 60-120mph while cruising aroung 3000-3250rpm in 5th gear. (IMG:style_emoticons/default/devil.gif)
any insights? (IMG:style_emoticons/default/huh.gif) muchas gracias..... |
Jeffs9146 |
Feb 20 2003, 04:40 PM
Speedo drive gear would be my first guess!
Jeff |
Jeffs9146 |
Feb 20 2003, 05:27 PM
scottb |
Feb 20 2003, 06:14 PM
any way to be sure that this is the issue? thanks......
Feb 20 2003, 06:35 PM
Cable is my guess. It seems they sometimes make the speedo reading bounce all around just before they break.... And the cable is cheaper than the angle drive.
--DD |
Jeffs9146 |
Feb 20 2003, 06:51 PM
Replace the cable first. Thats what I did. When that didn't work I got the Gear.
Jeff |
Brad Roberts |
Feb 20 2003, 10:13 PM
Cable. Its winding up and releasing.
Use a drill with a flat blade screw driver tip in it and remove the cable from the angle drive... spin it with the drill and have somebody watch the speedo needle. You might be able to "feel" the bind in the cable by just turning it with a screw driver. When you have it disconnected from the angle drive.. grab the tab hanging out and see if you can turn it back and forth (a lot) this means it is toast. Most of them have very little gear slop. B |
Lo-Fi Version | Time is now: 20th May 2024 - 12:06 AM |
