has anyone put a frame under the pan |
drive-ability |
Mar 28 2006, 05:25 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I thought I might ask, I know there are a lot of kits which attach to the inside and outside but they are just sheets. Has anyone seen a under pan type support set up? (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
byndbad914 |
Mar 28 2006, 05:34 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
nope, not that I am aware of - but actually another reason why I am going tube chassis - I am going to have a full length skid plate under the engine/trans combo in the car.
That said, you could easily fab something to mount to your engine cross bar, extend up to the firewall and mount at the firewall. For the back support, could probably drop some tubing down from the back cross support behind the engine. I was going to do this to my car as is, but then as stated above. Good luck! |
Mueller |
i've seen/heard of people adding tubes to the internals of the longs ....not too much clearance under the car..of course the wasserpumper guys run lines under there so there is some room........
bd1308 |
Mar 28 2006, 06:35 PM
Doug Leggins has a parts car I was almost intrested in, that featured flat stock (really thick) that extended from the suspension console all the way up to the front somewhere past the long (not by his doing I think--a PO feature). Welded pretty good to the car, he drove it while everything else rusted away....
Last I heard it was at his house. |
rick 918-S |
Mar 28 2006, 06:39 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I had a parts car that had 2" heavy wall square tubing welded under the car as a support, didn't help.
Tobra |
Mar 28 2006, 07:06 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
It depends on what sort of rigidity you seek. On a Bug convertible, there are reinforcements that run parallel to the long axis of the car, at the lateral sides of the pan, to make it more resistant to folding up. These are square section, perhaps 30 mm across. Whenever I get the car back, I will weld an "X" shaped brace connecting these two "longs".
Mueller |
Mar 28 2006, 07:11 PM
sounds like the fix to help the "fox" bodied Mustang 5.0 chassis.... |
Tobra |
Mar 28 2006, 07:27 PM
You can't twist a triangle, that is what I am thinking
Mike D. |
Mar 28 2006, 07:36 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Funny you mention this, we just put this exact thing in the trash. It was a homemade cross bar mount for a 6 engine two angled metal bars that ran to the fire wall...Tried to give it away and everyone just laughed at it.. |
Mar 28 2006, 08:23 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you are going to put a complete skid plate under the engine and tranny, please think about where the hot air will go once it exits the engine tin. Also, the transmission needs fresh air to keep cool as well. Rich |
jd74914 |
Mar 28 2006, 08:31 PM
He has a v8 and a dry sump tranny so that shouldn't be a problem (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
byndbad914 |
Mar 28 2006, 08:50 PM
thanks Jim... info is correct, I have a dry sump system and will be adding a trans pump and a PWR oil cooler and trans cooler with integrated fans to the car. They will be in my hot little hands (hot because the money they will cost me will have been burning a hole apparently (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ) this Friday.
But, that said, even if you don't have all of this but a regular V8 car, you could still skid plate underneath the trans and engine. there is still plenty of exposed area around the bottom of that car to get whatever air is available there. I don't think we are talking about completely skinning the underside of the car, just an oil pan skidplate. Maybe I misunderstood the original post.... wouldn't be the first time (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Mar 28 2006, 08:55 PM
It was something about flames in a pan..maybe frying eggs in a pan...I cant remember...
The skid marks under your rear...now thats more like it... maybe twins..long skid marks to protect the oil so it wont hit the driveway??? R |
drive-ability |
Mar 28 2006, 11:33 PM
I do see how some guys might just hack a peace of steel up and weld it in. There is room however looking at the body pan theres no real good places to attach it to. It would be a snap to make a box and "X" it , but securely attaching it to the body would be the most difficult part. Like welding a roll bar to tin foil (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
Mar 29 2006, 01:26 AM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
why? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 11:57 PM |
