Lifters..., What's the least evil? Need opinions... |
Tom Perso |
Mar 29 2006, 05:45 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Hello, Jake - were you talking to me? I've never had a cam failure... (IMG:http://www.qtm.net/~persot/webcam/Bad%20Lifter.jpg) (IMG:http://www.qtm.net/~persot/webcam/Cam%20Chunks.jpg) (IMG:http://www.qtm.net/~persot/webcam/Worn%20Cam.jpg) Those lifters and cam have about 1 hour of running time on them. Luckily, with the support of Mr. Raby and my parts supplier, I was able to get out of that mess fairly cheap (parts were replaced gratis), but my labor of rebuilding the whole engine was not fun. At least I got to bump the C/R up a bit (up to 9.5:1) and do a few other tweaks (while I had it apart, yah know?) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Do it right once. Don't play with a loaded gun. Tom |
davep |
Mar 29 2006, 06:19 AM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Especially playing Russian Roulette with a gun loaded only one shell short. |
Mueller |
Apr 4 2006, 10:18 AM
I found the cam....I lied, it is a Engle racing cam brand...
Model FK-10 according to the spec card in the box: valve lift .500 (intake and exhaust) running duration 306 gross cam lift 383 lobe centers 108 duration @ .050" is 268 I'll scan the card later on today |
yeahmag |
Apr 4 2006, 10:35 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I think an FK-10 is a ratio rocker cam (at least it was for a Type I). Probably wouldn't work for me... Let me know if I am wrong.
-Aaron |
Mueller |
Apr 4 2006, 12:22 PM
I have no idea.....all I could think to do is contact Engle and ask if it'll work with stock rocker arms (I was going use the Pauter rocker arms at them time, so you might be correct) |
yeahmag |
Apr 4 2006, 12:31 PM
I'll do the leg work... You have done enough all ready!!!
Thanks. -Aaron |
Lo-Fi Version | Time is now: 1st May 2024 - 06:29 PM |
