> type of oil for the six, should i be running 20-50
pete-stevers
post Mar 29 2006, 02:50 PM
saved from fire!
need to know what type of oil to by for the six....aprox how many litres
Eric_Shea
post Mar 29 2006, 02:59 PM
PMB Performance
Which 6? 3.0?
ArtechnikA
post Mar 29 2006, 03:00 PM
rich herzog
~9 liters says the spec book and owners manual.
assuming stock oil tank, no external cooler, etc...
assuming 3,0 or less - but if it were bigger, you'd probably have an external cooler...
20-50 is fine, especially for dino oil and a summer car.
i like 15W-50 synthetic. but the engine is pretty flexible in this regard.
too much oil is bad - it'll just puke out the tank breather and make a mess, or get sucked into the intake and make a mess -and- an oil cloud ...
pete-stevers
post Mar 29 2006, 03:07 PM
saved from fire!
it is a 3.0 six with a 914-6 tank, and a remote oil cooler up front
Eric_Shea
post Mar 29 2006, 04:16 PM
PMB Performance
The weight should be fine.
I've heard another 4 qts for the cooler and lines. CHECK THOUGH.
J P Stein
post Mar 29 2006, 06:49 PM
Irrelevant old fart
I get 10 qts out at an oil change. I initially put in 12 qts.
I use 10-40 plankton.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Allan
post Mar 29 2006, 07:02 PM
Teenerless Weenie
Mine runs on 20-50 and seems to do well. It's a 2.7 with no external oil cooler and runs around 180 to 200 oil temp.
The hottest it ever got was 210 over the grapevine and then cooled right back to 180 after I crested the top.
- Lo-Fi Version Time is now: 30th July 2025 - 07:56 PM
