914 trans in a 911 |
dweymer |
Apr 2 2006, 03:52 PM
Member Group: Members Posts: 110 Joined: 22-November 05 From: orlando, fl Member No.: 5,167 |
Is it possible?
What would be needed other than a diff tailpiece? Thanks |
bd1308 |
Apr 2 2006, 03:53 PM
flipped diff.... |
Cap'n Krusty |
Apr 2 2006, 05:08 PM
Nose cover, selector shaft, shift rails, output flanges, and flip the ring gear over. That last item requires a not insignificant investment in tools and substantial knowledge. The Cap'n |
dweymer |
Apr 3 2006, 10:02 AM
I am aware of the issues with r&p, from watching others deal with it.
From PET, looks like I need: 901.301.221.01 intermediate plate 901.301.031.12 end plate 901.332.209.12 flange (2) 901.302.132.11 shift selector |
brant |
Apr 3 2006, 10:04 AM
914 Wizard Group: Members Posts: 11,617 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm guessing the intermediate plate bearings too...
before long it will be as cheap for you to buy a used 915 and replace what you have... less labor less fabrication and you can recoup some of your money by selling off parts from the fried 915 you remove. brant |
dweymer |
Apr 3 2006, 02:15 PM
The intermediate plate is the same, no?
Cap'n Krusty |
Apr 3 2006, 02:49 PM
The 901 and 911 trannies have a threaded boss on the intermediate plate for the throttle bell crank. If this is a project for your 74 911, you will also need the intermediate plate, or some way to mount the bell crank rod on the one you have, a flywheel, a clutch kit, and a new clutch cable, as well as the shifter assembly, the shift rod, and shift coupler. Oh, and the locating fork from the side of a tail shifter trans. This is getting to be a fairly major project, no? |
Dr Evil |
Apr 3 2006, 02:55 PM
There is a dummy boss on the intermediate plate of the 901. You can drill it and tap it for placing the stud for the bell crank.
brant |
Apr 3 2006, 02:57 PM
Perhaps sell off some of your good 914/901 parts to help fund the replacement 915?
putting a 901 tranny into your 911 is going hurt your resale also. Its not untypical to find another 300-400 worth of bearings and misc. items once you start the project also. brant |
brant |
Apr 3 2006, 03:01 PM
Mike, is the dummy boss the same for a 901 and a 914 tranny... he wants to flip the R/P and install the 914 tranny into a 2.7 911 chassis in place of his bad 915 brant |
bondo |
Apr 3 2006, 05:26 PM
I'm pretty sure the nose cone of the aluminum 901s won't fit a 914 intermediate plate. (I have a 902 and it's close, but the bolt pattern is a little different, and I think the 902 and aluminum 901 take the same intermediate plate)
You'd have to make sure you found a magnesium nose cone, I don't know what year 911s have magnesium 901s though. |
markb |
Apr 3 2006, 05:35 PM
It sounds like with all the work & money needed to make a 901 work, you might be better off just repairing/replacing the 915.
Mr.C |
Apr 3 2006, 06:04 PM
Easy does it Group: Members Posts: 611 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
I'm looking into doing the same thing in a bus. Same idea basically. I read here on how some of the guys are using 914 trannys with 901 nose cones. http://www.germanlook.com/Forums/forumdisp....php?forumid=13
Lo-Fi Version | Time is now: 1st May 2024 - 06:31 PM |
