NORD |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest ![]() |
Need to get a head count for Breakfast (IMG:style_emoticons/default/chowtime.gif) As of now I have
Kelty 360 Mark 1 Greenie Curt 2 Messix Troy 1 Aircooledguy Nate 2 Helios Chris 1 Root werks Dan & michele & son 3 Bmtrnavsky 2 Mel & Barbra ( 911 ) or ( 914 ) 2 Dave & Cindy 54 Allard 2 Nord Any body to add? |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,799 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
I can do the Smokey Point Rest Stop at 7:45 too. Thats where I live... (Smokey Point not the rest stop!) Isn't that a bit early for 9:14 in Bellingham though? Nord lives out in cow country b'tween b-ham and lynden.... so i add a little time. and we'll wait til 'bout 8 or so before we leave to let the slow pokes greenie and kelty show up.... ah maybe we'll leave right at 7:45 before kelty gets there! OK, we'll be at the Smokey Point Rest Stop by 8:00. Just remember, if you leave without us, we'll hunt you down. (IMG:style_emoticons/default/fighting19.gif) Mark, would you have room for the 'kid' if he decides to go? |
helios |
Member ![]() ![]() Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest ![]() |
Nord, give me a shout. What time would you like me there tomorrow am? Can probably bring the teener. Seem to have gotten the sticky thottle fixed....for the moment.
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Sitting on the fence. A definite maybe. It's hard to resist maybe the last really nice driving day.
Dave |
NORD |
Chris About 8:00 should be good. Nate will be here about then also Dave glad your concidering comming. Rattle Kevin's door as you pass through T town. (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/driving.gif) |
greenie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest ![]() |
Hey Guys,
I'm having a little trouble... Just adjusted the valves, points plugs I'm having trouble with the dwell & timing. It's like she is running lean & hot... Any advice? Greenie |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
Hey Guys, I'm having a little trouble... Just adjusted the valves, points plugs I'm having trouble with the dwell & timing. It's like she is running lean & hot... Any advice? Greenie set dwell then set timing. are you using a dwell meter or are you setting them by gap? |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,158 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Hey Guys, I'm having a little trouble... Just adjusted the valves, points plugs I'm having trouble with the dwell & timing. It's like she is running lean & hot... Any advice? Greenie set dwell then set timing. are you using a dwell meter or are you setting them by gap? I just talked to him, he's using a dwell meter. |
messix |
Hey Guys, I'm having a little trouble... Just adjusted the valves, points plugs I'm having trouble with the dwell & timing. It's like she is running lean & hot... Any advice? Greenie set dwell then set timing. are you using a dwell meter or are you setting them by gap? I just talked to him, he's using a dwell meter. did he find the right timing mark.... the one you have to use a mirror to see? |
greenie |
Hey Guys, I'm having a little trouble... Just adjusted the valves, points plugs I'm having trouble with the dwell & timing. It's like she is running lean & hot... Any advice? Greenie set dwell then set timing. are you using a dwell meter or are you setting them by gap? I just talked to him, he's using a dwell meter. did he find the right timing mark.... the one you have to use a mirror to see? A big thanks to Troy! (IMG:style_emoticons/default/welcome.png) He said I had permission to drive the Taildargger (IMG:style_emoticons/default/driving.gif) , I'll fuch with the Green One later. |
InkyP |
MeanGreen ![]() Group: Members Posts: 46 Joined: 24-March 10 From: Lynnwood, WA Member No.: 11,498 Region Association: Pacific Northwest ![]() |
Wish I could make it but work calls! Take plenty of pictures please.
You guys have fun and drive safe. You know that fast does mean safe in a Teener! |
NORD |
I have an Infinity G 35 Coupe w/ 6 speed in the garage for you Greenie. (IMG:style_emoticons/default/driving.gif) |
Eddie914 |
Unregistered ![]() |
I wish I could make the drive (IMG:style_emoticons/default/sad.gif)
Have a great day (IMG:style_emoticons/default/driving.gif) Cheers Eddie |
messix |
oh no!!!
good news and bad news..... i think i found my no start with the key problem... i fiddled with the connections at the reley board and now she starts every time!!!! thats the good news.... the bad news.... i now have a pretty bad lifter knock that does not change from pulling plug wires, looks like i either bent a push rod or [most likely] droping a valve seat (IMG:style_emoticons/default/headbang.gif) . well i'll have to drop the engine and do all the things that i was saving to do at once, clean and reseal, back date H/E change all vac and F/I hoses. and find out if i have a bad head or not!!! i might be looking for a good used 1.8 head. before you guys start flaming about using a used head let me remind you all that there is no way i can afford new or rebuilt heads.... no way, no how right now (IMG:style_emoticons/default/headbang.gif) |
NORD |
Troy sorry about bad news, hope its not as bad as you suspect. How about the run Today? to many long high revs? maybe the car just needs a nice quit day off. (IMG:style_emoticons/default/idea.gif) |
messix |
Troy sorry about bad news, hope its not as bad as you suspect. How about the run Today? to many long high revs? maybe the car just needs a nice quit day off. (IMG:style_emoticons/default/idea.gif) coming down i was running 6k rpm thru the hairpins. i think i just got the heads hot and when i stopped at the resturant the head cooled down enough that when i left the seat started to drop. it wasn't making any noise when i restarted at the resturant but when i stopped to get Lilli it was making lifter noise pretty bad. like a collasped hyd lifter. i was hoping it was just hot thin oil and would stop when the oil and engine cooled down. |
bmtrnavsky |
Member ![]() ![]() Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region ![]() |
Troy sorry about bad news, hope its not as bad as you suspect. How about the run Today? to many long high revs? maybe the car just needs a nice quit day off. (IMG:style_emoticons/default/idea.gif) coming down i was running 6k rpm thru the hairpins. i think i just got the heads hot and when i stopped at the resturant the head cooled down enough that when i left the seat started to drop. it wasn't making any noise when i restarted at the resturant but when i stopped to get Lilli it was making lifter noise pretty bad. like a collasped hyd lifter. i was hoping it was just hot thin oil and would stop when the oil and engine cooled down. That sucks Troy! It was running strong today too. (IMG:style_emoticons/default/sad.gif) shoot me a message if you want or need help tearing it down. I still have a LOT to learn about these cars! On a side note, anyone want to go to the Everett Silvertips / Portland Winterhawks game Wednesday? Wife can't go and I have 2 good tickets! |
TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 837 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
mike do you know of a good route for fall colors drive down south? maybe you could head up that and the next good weather week end we'll hit that. I'm in for the 9th !!! The weather looks like it will be good-OK for next week, I will cancel golf and make it a Teener weekend. We can 1- Hurricane ridge, 2-Cresent lake- Cresent beach, 3-La Push, 4-Hwy 112 to Neah Bay, 5 Hood canal to Hoodsport and round to bremerton, 6-alll the above. All good.... BBQ at my house after (IMG:style_emoticons/default/chowtime.gif) with accmodations (IMG:style_emoticons/default/sheeplove.gif) for anyone who cant make it home, leagaly (IMG:style_emoticons/default/beerchug.gif) Let me know If any golfers want to come out early on Friday Golf packages available...... TCI |
messix |
mike do you know of a good route for fall colors drive down south? maybe you could head up that and the next good weather week end we'll hit that. I'm in for the 9th !!! The weather looks like it will be good-OK for next week, I will cancel golf and make it a Teener weekend. We can 1- Hurricane ridge, 2-Cresent lake- Cresent beach, 3-La Push, 4-Hwy 112 to Neah Bay, 5 Hood canal to Hoodsport and round to bremerton, 6-alll the above. All good.... BBQ at my house after (IMG:style_emoticons/default/chowtime.gif) with accmodations (IMG:style_emoticons/default/sheeplove.gif) for anyone who cant make it home, leagaly (IMG:style_emoticons/default/beerchug.gif) Let me know If any golfers want to come out early on Friday Golf packages available...... TCI i might be sporting the metro for this run (IMG:style_emoticons/default/dry.gif) |
TC 914-8 |
mike do you know of a good route for fall colors drive down south? maybe you could head up that and the next good weather week end we'll hit that. I'm in for the 9th !!! The weather looks like it will be good-OK for next week, I will cancel golf and make it a Teener weekend. We can 1- Hurricane ridge, 2-Cresent lake- Cresent beach, 3-La Push, 4-Hwy 112 to Neah Bay, 5 Hood canal to Hoodsport and round to bremerton, 6-alll the above. All good.... BBQ at my house after (IMG:style_emoticons/default/chowtime.gif) with accmodations (IMG:style_emoticons/default/sheeplove.gif) for anyone who cant make it home, leagaly (IMG:style_emoticons/default/beerchug.gif) Let me know If any golfers want to come out early on Friday Golf packages available...... TCI i might be sporting the metro for this run (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/WTF.gif) What does that mean? Geo Metro? Next question, Is there going to be a Pennisula rin next week? |
Lo-Fi Version | Time is now: 27th September 2025 - 06:34 AM |
