332 Pages V « < 288 289 290 291 292 > »
> teener tuesday puget sound teeners, or whats going on in the pnw
KELTY360
post Aug 3 2018, 07:00 AM
Post #5781
914 Neferati
QUOTE(jcambo7 @ Aug 2 2018, 09:07 PM) *
QUOTE(PanelBilly @ Aug 2 2018, 09:32 PM) *
All because you dropped the clutch?
I think the fact that two of the axle bolts on the left axle were not tight at all, aided in it. The torque sheared the other two axle bolts and possibly threw the axle up into the starter with so much force it caused the case to crack around it. The right axle bolts were all the way tight.
That's wild. Were you at idle?
jcambo7
post Aug 3 2018, 08:04 AM
Post #5782
QUOTE(KELTY360 @ Aug 3 2018, 08:00 AM) *
I think the fact that two of the axle bolts on the left axle were not tight at all aided in it. The torque sheared the other two axle bolts and possibly threw the axle up into the starter with so much force it caused the case to crack around it. The right axle bolts were all the way tight.
Yep.
AfricanHijinx
post Aug 3 2018, 09:55 AM
Post #5783
I also have an empty case that you can have but I am up north
jcambo7
post Aug 3 2018, 12:22 PM
Post #5784
QUOTE(AfricanHijinx @ Aug 3 2018, 10:55 AM) *
Thanks. I will let you know if Todd's doesn't work out. I drive up to Everett a lot to visit my parents so its not too far for me.
AfricanHijinx
post Aug 3 2018, 03:17 PM
Post #5785
QUOTE(jcambo7 @ Aug 3 2018, 11:22 AM) *
no problem hope it works out
PanelBilly
post Aug 3 2018, 03:34 PM
Post #5786
I think I have new axle bolts and the right schore washers if you need them
sportlicherFahrer
post Aug 9 2018, 09:12 PM
Post #5787
Nothing to see here.
Anyone have an LE spoiler in good shape collecting dust? In the market for one. Figured I'd ask you folks here before trying the classifieds.
worn
post Aug 13 2018, 04:46 PM
Post #5788
Did you notice the starter teeth? Not sure that damage all occurred during the axle incident. Best check the ring gear, which I am sure you would when replacing the transmission.
xmotox
post Aug 13 2018, 08:36 PM
Post #5789
i have two trans that i rebilt at dr evil clinic years ago. and a couple starters. give me a call 253 381 3516 logan
sportlicherFahrer
post Aug 17 2018, 09:19 PM
Post #5790
Is there a Nord memorial drive this year? I don't remember seeing a thread for one...
PanelBilly
post Aug 18 2018, 10:04 PM
Post #5791
I’m in Wilsonville tonight and planning on checking out the world of speed tomorrow at 10 when they open. Anyone want to join us for breakfast?
jcambo7
post Aug 19 2018, 11:57 AM
Post #5792
Just wanted to say thank you to the PNW guys that reached out and offered me a free starter and an empty trans case (914werke, Tbrown4x4 and AfricanHijinx). I ended up buying one of the rebuilt transmissions from xmotox and he gave me a great deal which I am very grateful for. Hopefully I can pay it forward to him, another PNW or 914world member in the future.
Now I am just waiting on new axle bolts, seals, and roll pin arriving Monday.
Is it feasible to put low or medium strength Loctite on the bolts? Or should I just stick with lock washers?
PeeGreen 914
post Aug 20 2018, 11:10 AM
Post #5793
Don't use loctite on these. The lock washers are fine. If you want you can get the pre drilled bolts for safety wire.
rhodyguy
post Aug 20 2018, 11:14 AM
Post #5794
New schnor/bellville? Locking Washers
914werke
post Aug 20 2018, 11:58 AM
Post #5795
Just make sure everything is "CLEAN"
I know some don't use them but I always take this sort of opportunity to
restore/replace grease & use new CV seals
rhodyguy
post Aug 20 2018, 12:23 PM
Post #5796
The pattern in the bolt heads needs to be nice. I wish bolts were available that worked with T25 tips. They're plenty cheap.
914werke
post Aug 20 2018, 12:49 PM
Post #5797
Hey just throw'in this out there but it seems it's been a while since the PNW crew got together en-mass (Kevs breakfasts aside)
Jim mentioned a artist point run as we've done in past as memoriam for our friend Nord ~?
There is also a small classic car show that one of my HS friends has been hosting for the past couple of yrs & has bugged me to participate In Wedgewood.
Suggestions ...interest ?
sportlicherFahrer
post Aug 20 2018, 01:24 PM
Post #5798
I'm down as long as its on a weekend. Hopefully not too early as I prefer the scenic route to completely avoid downtown Seattle construction/traffic. Too many near hits going through there to subject the 914 to that abuse... (IMG:style_emoticons/default/ar15.gif)
Oh (IMG:style_emoticons/default/stromberg.gif) , I'm starting to sound more like Kevin (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif)
scallyk9
post Aug 20 2018, 01:34 PM
Post #5799
QUOTE(sportlicherFahrer @ Aug 9 2018, 08:12 PM) *
I have a replica gathering dust at Eurotech Bodywerkes. It's in great undamaged condition from my Bumblebee so it is Sunshine yellow. I only took it off to replace it with a genuine one...for a LOT more money. PM me if interested.
sportlicherFahrer
post Aug 20 2018, 01:42 PM
Post #5800
Thank you scally. I ended up finding one from another member. Got busy putting the car back together and forgot to post up that I found one.
- Lo-Fi Version Time is now: 14th September 2026 - 03:44 AM
