| PanelBilly |
Aug 16 2019, 09:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,998 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Ok Sunday at 11.
| sportlicherFahrer |
Aug 16 2019, 06:51 PM
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,125 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
Should be able to make it. 914-less this time though. (IMG:style_emoticons/default/sad.gif)
| 914werke |
Aug 17 2019, 03:41 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,746 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Ok ill try to drive mine but my L hand is still healing from surgery wed. (IMG:style_emoticons/default/sad.gif)
Sounds like only 4 of us? |
| piscean914 |
Aug 29 2019, 05:23 PM
Member ![]() ![]() Group: Members Posts: 111 Joined: 6-February 04 From: seattle, wa Member No.: 1,637 |
hey guys - it's that time of year again for the annual lemay car show and lucky auction - https://www.lemaymarymount.org/42nd-lemay-annual-show
- this will be my 3rd year going, and i highly recommend it to everyone - you can park at the event in your collector car i.e, 914 - this year, i see there are no less than 4 914's for sale at the auction - check the auction list - http://www.luckyoldcar.com/2019-fall-classic/ - there is a ton of real cool car stuff, old timey stuff to check out, and there's food, drinks, etc - i'll be there in my latest project - not a 914 or porsche though - hope to see you there! brad k |
| PanelBilly |
Aug 31 2019, 10:25 AM
I came out to LeMay’s. Wife has two of the grandkids today, so this was a much smarter way to spend the day.
| rhodyguy |
Aug 31 2019, 12:20 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The Hudson Brad?
| sixnotfour |
Aug 31 2019, 12:39 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,365 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
:popcorn:auction 914s
Attached thumbnail(s) Attached image(s)
| piscean914 |
Aug 31 2019, 05:41 PM
| rhodyguy |
Sep 1 2019, 07:15 AM
Mr LeMay was a man with vision. From a towing company to a major player in refuse hauling. The 3 acres behind us was one of the many parcels of land in Pierce County owned by the LeMay family.
| sixnotfour |
Sep 1 2019, 12:21 PM
| Bruce Hinds |
Sep 4 2019, 09:52 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 764 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I know I've been lingering in the shadows for a lot of years missing being part of the goings ons . . . . Well, the little car laid a big egg today.
This first went in 34 years ago and was my daily driver for a long time in the mountains of Colorado and California. It's been off the road for nearly 10 years . . . Maybe 2020 will be the year the little black beast comes back to life! |
| Tbrown4x4 |
Sep 5 2019, 03:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 709 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
Glad you popped in Bruce. It was great talking to you in the Fred Meyer parking lot ( a while ago).
| Bruce Hinds |
Sep 5 2019, 07:30 AM
Glad you popped in Bruce. It was great talking to you in the Fred Meyer parking lot ( a while ago). Great to meet you too . . .. I'm here often, just don't get to the other side much to try and catch up with the guys. We had a gathering in Gig Harbor several years ago and I actually had a chance to meet several of the TT crowd. My car wasn't running then either . . . I should be here more often as this progresses . . . |
| Bruce Hinds |
Sep 16 2019, 10:19 AM
Now that I have this monster apart, it's time to try and figure where to get some local work done on this side of the water.
Brakes - I'll need to have the calipers redone, teener in the rear and 78 911 SC stuff up front with wheel bearings for and aft. Trailing arm advice? I'll have a pair for sale depending on which I use. Installed now are the stock units, years ago I purchased a pair of boxed units primed and ready. Not sure I need them since I don't track the car. Opinions? Clutch - the conversion supposedly used a stock flywheel machined to fit the chevy crank - it's a 200mm diameter with a heavy duty pressure plate. Kennedy engineering that supplied the unit doesn't make them anymore. What I have is still good, but I'd like to know I can get parts. Does the little place in Gorst do wheel bearings, cv's and brakes? Bruce |
| Tbrown4x4 |
Sep 16 2019, 10:51 AM
Hi Bruce. I'm not sure if John (Morris Racing Engines) would do the brakes and such, but it wouldn't hurt to ask.
I can do the brakes, wheel bearings etc, depending on what finish you want on the calipers. You can send the bare calipers to PMB, and he'll plate them for $80 each, I believe. I've been using caliper paint with success over 2000 degree primer. I would probably use the reinforced trailing arms because of the extra weight and power, regardless of any future abuse. Plus, you already have them. Is the flywheel stock 6 or stock 4? Might have to look for part numbers or compare with other parts. Have you called Kennedy to see if they can help? Oh, and I have a pair of front wheel seals for a 6 that may match what you have. I ordered by mistake, and you can have them free. |
| rhodyguy |
Sep 16 2019, 11:00 AM
Goldline Brake in Port Orchard as a local alternative.
| PeeGreen 914 |
Sep 20 2019, 12:10 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
There may be a new 914 coming to the NW (IMG:style_emoticons/default/piratenanner.gif)
| sixnotfour |
Sep 20 2019, 12:26 PM
What a "New" 914 .. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/happy11.gif)
| sportlicherFahrer |
Sep 20 2019, 12:27 PM
And you even have a donor car for it!
| Bruce Hinds |
Sep 20 2019, 12:28 PM
Lo-Fi Version | Time is now: 16th September 2026 - 08:16 AM |
