quadracerx |
Member ![]() ![]() Group: Members Posts: 428 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest ![]() |
Hi...
God I hate to sound like a wimp....lol..but I am coming down with a cold, so working outside is not so good.... If you plan on resheduling...Im in....but today cause of the weather...and my cold...i guess Im out... Sorry.... Steve |
Eric Hagelin |
Member ![]() ![]() Group: Members Posts: 88 Joined: 4-July 06 From: Seattle Member No.: 6,375 ![]() |
That's okay, Steve - no worries.
Anyone else out there (who was planning on coming) feel strongly, one way or the other? Chris? Sportlicher? Rand? (Everyone else was a "maybe", but you three all are/were "yes" on the work party.) |
mstein95 |
Back when grey Levi's were the rage. ![]() ![]() Group: Members Posts: 404 Joined: 1-May 06 From: Eugene, OR Member No.: 5,959 Region Association: Pacific Northwest ![]() |
I'm OK with a reschedule (prefer it due to weather).
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Bunch of weenies. (IMG:style_emoticons/default/tongue.gif) I was planning on showing. I don't melt in this weather. I'll be damned if I let it stop me from doing what I want. Actually, it's only windy, not rainy here right now.
Seriously though, no big to me either way. I'll check back here for the official status report around 12:30. |
Eric Hagelin |
OK, one positive 'yes' (even in a little rain) is good enough for me. Thanks, Rand. I will be there. If no one else can make it due to weather, etc., that's okay.
It's on - I will not be there 'til 1:00pm, though. I'll bring some sausages and rolls (in case Chris doesn't make it), and hot coffee will be brewing. |
sportlicherFahrer |
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest ![]() ![]() |
Weather update? I still plan to come if it isnt pouring/blowing like the dickens. Might be there a little later than 1 though. Where is Chris??? (IMG:style_emoticons/default/confused24.gif)
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,737 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
I am on my way. I will bring brat's and buns.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
did you guys get the car to run?
k |
effutuo101 |
I had to leave about 4, and it wasn't running when I left. This is a wierd one. the car was running when I showed up. Rand and Eric had used the relay from the headlights for the fuel pump relay and the car was idling nice. But after about 5 minutes, it shut off. It would then run intermittently for a few seconds and then shut off. You could smell varnish, but no gas. Jim found a wire that was burned up (connector fell off in his hand) and fixed that. The strange thing is that when the relay was put back into the headlight, the lights wouldn't pop up. we tried several relay's to the same result. If you hold the relay, you can feel it click, but then nothing. Any clues?
Eric Hagelin |
Thanks to all who showed up to help on my car - I really appreciate it.
No, Kevin, the car is still inop - but Rand and Chris got to witness the strange intermittent problem I'm having! She started up and ran/idled very smooth for about 15 minutes, and then completely, immediately cut-out without warning. We checked a number of different components (fuel pump, injectors, relays, intake air sensor stator flap movement & ohm readings, etc.) and the gremlin is a little hard to pin down. Jim pulled my ignition coil and dropped his in there, to see if that was the culprit, but my coil is fine... however, during that process, he found that the wiring from the ignition coil through the harness to the relay plate was seriously degraded. The terminal broke off in his hand while removing it from the coil! I'm going to replace the wiring, and clean up all my grounds. If it doesn't run after that, then I'm at a loss on what to do next. Maybe Troy would have some ideas? (You've got an L-jet, right, Troy?) Thanks again, guys. Time is precious, and you guys took some to help a brother out. |
effutuo101 |
I think we need to get Troy's car sitting next to it and go wire by wire. the PO had some interesting wiring choices.
Eric Hagelin |
I had swapped out relays for the fuel pump before yesterday, by the way. I don't think that's what got the car to start and run/idle the way it did - because it will start and run fine (sometimes for days) - and then just cut-out mysteriously.
What WAS strange, was that I pulled the headlight relay (Rand witnessed my working headlamps) out and put it in the fuel pump relay. I had several spare relays, and we put them in the headlamp slot, but the headlamp motors wouldn't lift. The lights came on, but no action on the motors. I thought maybe the relays were no good (we tried a few), and Rand pulled one from his headlamps, but it didn't work either. Weird, the headlamp motors were working fine ten minutes before! Got to be some cheesy wiring in there somewhere?! Damn thing sure looks good, though - even when she's sitting still and inoperative! I love that tempermental bitch! |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
i can come over on saturday with my car and a real volt ohm meter.
dinomium |
Git on a chair son, all the good stuff is goin over yer head! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest ![]() ![]() |
Sounds like a bad ground or where the four leads connect to the pos battery terminal.
dinomium |
slightly of our topic... I saw this in the Paddock, Northwest Hillclimb There are two in Oregon and one in Idaho! Pretty kewl, huh?
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Eric,
I had a similar relay problem for the relay that operates the power to the blower, horn , and in my case the radio. Put relay in aftre checking that it was good. Worked one day , then stopped working. Finally found out that the female plug that the relay goes into was not soo good. Here is what I did to overcome the bad connection. Pull the relay and use a small wire brush to clean the socket as good as you can , take the relay prongs and try to slightly bend them apart ( spreading them wider, and wire brush them also. Did this to all of my relays and now - no more intermittent power problems. Hope this helps. Tom |
messix |
ok guys, every one ok in this latest snow storm?
how about your commutes? being a cable guy has it's advantages in getting around traffic, knowing where ever street in the pierce, king and snohomish county go to! |
mstein95 |
I'll be taking the teener to work today (IMG:style_emoticons/default/sad.gif) wife's car is in the shop and she bumped me from the DD. Slow and steady..wish me luck. Any word on the road conditions from Oly to Shelton? (IMG:style_emoticons/default/blink.gif)
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,408 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Commute was a piece of cake (IMG:style_emoticons/default/biggrin.gif)
I was in Phoenix yeterday morn 74 degrees, Arrive in Seatac 2PM by the time I drive to Mill Crk its Snow/Hailing like the bejeasus (IMG:style_emoticons/default/headbang.gif) 2" in about an hour. I had to fly home early after having an run in with an cactus while Golfing at the Phoenician (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/wub.gif) |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Commute was a piece of cake except for snow blowing horizontally across the Narrows Bridge. I came in and all the patients cancelled but 2. With the overhead I get to pay for the pleasure. Not the best day.
Dave |
Lo-Fi Version | Time is now: 24th September 2025 - 12:36 PM |
