Front Air Dam Project |
drew365 |
Apr 2 2006, 08:45 PM
Even though my car is a lowly Chalon, I wanted to share the air dam project I worked on the last two weekends. I got the inspiration for a front shelf and side winglets from this pic of the Miura prototype. My car often gets light in the front end at high speeds and this looked like a way to keep some of the air from rolling off the bottom of my front bumper and under the car which creates lift. Here's was the inspiration:
drew365 |
Apr 2 2006, 08:50 PM
I have to resize my pics. I'll be back.
Trekkor |
Apr 2 2006, 09:07 PM
I'm interested...
drew365 |
Apr 2 2006, 09:08 PM
OK, I started with a flat sheet of .063 aluminum, traced my outline and cut with a dremel.
drew365 |
Apr 2 2006, 09:13 PM
Here is the basic shape with winglets and attachment flanges bent
drew365 |
Apr 2 2006, 09:15 PM
Here is a side view of a winglet after install. I also added side brackets to keep airflow into the oil cooler:
drew365 |
Apr 2 2006, 09:16 PM
Here's the front view:
Aaron Cox |
Apr 2 2006, 09:18 PM
looks like fun
is that an F car above it? |
drew365 |
Apr 2 2006, 09:19 PM
I extended a flat pan to clean up the underside at the front. This also keeps the air that is exiting my oil cooler from being dumped under the car. It now is funneled to the sides and exits at the front of the wheel wells which is a low pressure area.
drew365 |
Apr 2 2006, 09:24 PM
Here is the full car with the new dam. Kind of reminds me of a locomotive. I'm thinking of naming the car Loco Motion!
Trekkor |
Apr 2 2006, 09:26 PM
Good stuff, Andy.
This gives me some ideas. Thanks. KT |
drew365 |
That's my '69 365 GT. After I finished this project I took both the 914 and 365 out for exercise. It was a good day! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Aaron Cox |
im sure home depot has you covered (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Trekkor |
Apr 2 2006, 09:33 PM
yes.
Elliot_Cannon |
Apr 2 2006, 11:28 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I'ts too bad you don't have access to a wind tunnel. Or you can dab your finger in some painit and make a bunch of little dots all along the spoiler, go out right away and drive it at speed. When you get home you can see the direction of the air flow along the spoiler. Might be a fun experiment. Your car looks great.
Cheers, Elliot |
VegasRacer |
Apr 3 2006, 04:07 AM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Looks good Drew. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
I think your design looks better on a Chalon than it would on a stock bodied car. Now I only hope it works like you planned. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:10 AM |
