One or Two GT3 seats for neo914-6?, need designer's or aesthetic advise... |
neo914-6 |
Apr 7 2006, 10:01 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
The drivers seat is mounted, just not sure the fixed passenger seat idea can "work". I can reshape the bottom and backrest to match but the shoulder support and headrest protrude.
The Audi dash shape will match the headrest and the door panels are reshaped as well. Two seats will have symetry but not at the dash. They will reduce the need for back padding if any but then it will look less "production". This is why I removed the cage and opted for the hidden Engman reinforcements. Making harnesses look "factory" is also a detail challenge... Attached image(s) |
neo914-6 |
Apr 7 2006, 05:43 PM
Thanks Pete and all, unfortunately the sketch only shows one view and details of the design. Yes the fixed passenger seat was/is a unique idea and I wanted to preserve that with a seat that doesn't lift you off the floor much. Most of the aftermarket competition buckets don't aesthetically "fit" the 914 except the ones that have adapted the stock headrest. I like Siverson's solution of integrating buckets without headrests but wanted to highlight the importance of the drivers seat. Having the headrest shape and flat targa band/rear window lines "work" is the obvious challenge. For one, the rear window will give way to a radiused shape at the inside corners (electric). The targa will be reformed with two head humps similar to the Lancia Ralley 036 breaking up the flatness while the top is on. Another plan is to use a harness bar similar to Joe Sharp's with double hoops. I made sketches of a fixed round passenger headrest and even considered late Bug semi-circular style but they didn't look right either. The passenger seat will be bolstered a little more than stock and the harness should be sufficient. Good idea on flattening the top, I hadn't thought of that... (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) Attached image(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 07:42 AM |
