Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
stock93 |
Sep 16 2003, 11:24 PM
Eventually I want to go bigger. I just dont have the money at the moment. Are the Heat exhangers the same where they bolt to the heads on the 1.7, 1.8, and 2.0? I'd like to build either a 2056 or a 2270. Any idea on the odd noise? Do the rivets in the cam gear come loose on these often?
John |
Lo-Fi Version | Time is now: 19th May 2024 - 05:44 AM |
