Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
Brad Roberts |
Sep 16 2003, 11:55 PM
Easy enough.. pull the muffler off and shake it around. If its rusted inside... shit will fall out..
Make sure you have a new set of gaskets ready to go back on. OR.. you can tap on the muffler and listen for moving parts... B |
Lo-Fi Version | Time is now: 17th May 2024 - 03:40 AM |
