Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
stock93 |
Sep 17 2003, 12:16 AM
I tapped on it with a rubber mallet just a second ago. I dont hear anything moving around in it. I wonder if the PO burned the valves bad enough to make them clatter. Would it hurt anything if I took the pushrods out cylinder and see if it went away?
John |
Lo-Fi Version | Time is now: 17th May 2024 - 01:59 AM |
