Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
Brad Roberts |
Sep 17 2003, 12:20 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The compression from what ever cylinder you pulled the push rods from would have nowhere to go... I wouldnt suggest it. Pull plug wires while the engine is running... and see if you can find a cylinder that "changes" when it has no load on it. Be careful with the spark.
B |
Lo-Fi Version | Time is now: 19th May 2024 - 06:28 PM |
