Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
Jake Raby |
Sep 17 2003, 12:56 AM
The sound could be a loose cam gear, or alos coulkd be a loose lower pin in the oil pump hitting the cam gear.......Or the thrust surface on the #3 cam bearing could be wiped out causing the cam to "dance" freely in the journals (this is heard more at low RPM on start up and shut down)
I would atleast rip it down and make it a 2056..... |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 PM |
