Tear it down?, My engine that is... |
stock93 |
Sep 16 2003, 10:50 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a 71 1.7. The compression is 132, 130, 140, and 112. If I squirt some oil in the cylinder with 112 it come up to about 165. Would you guys go ahead and tear it down to re ring it or just run it? It has next to no power. I think I have some other problems as well. Its slower than a 1500sp in a ghia. Its also making a strange noise from idle to around 3000rpm. Then it just goes away. The best way I can describe it is it sounds like a rickety old washing machine. Any ideas?
John |
Jake Raby |
Sep 17 2003, 11:50 AM
I see the riveted gears fail all the time.....mostly it was the MAGNESIUM cam gers used in the early engines, not the rivets.
If thats what it is, she won't last long at all......the ,metal transferring through the oil system will "extrude hone" the bearings..... if in doubt, rip it out and go from there. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:40 AM |
