Tear it down?, My engine that is... |
HarveyH |
Sep 17 2003, 05:47 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
My PO had the engine rebuilt (1974 2.0 to a 2056) and the shop that did the work (IMG:style_emoticons/default/ar15.gif) (no longer in business) didn't lock down the cam gear bolts properly. They walked out and ate into the oil pump body. If you're engine has been rebuilt before, you MAY have a bolt-on cam gear rather than the factory rivet-on, I believe even if they didn't use a hotter profile. If this is your problem, you'll get a clicking at 1, 2, or 3 times engine speed, depending on how many bolts are loose. In my case, the sound did change with load and run-up or run-down conditions.
Harvey |
Brad Roberts |
Sep 17 2003, 11:27 AM
I knew the bolts *could* back out.. but I havent seen any rivet failures. Now you have me scared about the last 3 engines I used bolt on cam gears from...LOL
B |
Jake Raby |
Sep 17 2003, 11:50 AM
I see the riveted gears fail all the time.....mostly it was the MAGNESIUM cam gers used in the early engines, not the rivets.
If thats what it is, she won't last long at all......the ,metal transferring through the oil system will "extrude hone" the bearings..... if in doubt, rip it out and go from there. |
Brett W |
Sep 17 2003, 11:59 AM
John email me at tooltime1@mindspring.com I am local and could possibly come by and give a diagnosis.
Brad Roberts |
Sep 17 2003, 12:03 PM
They used mag cam gears on the type 4's ?? CRAZY. Learn something new every day.
B |
Brett W |
Sep 17 2003, 12:20 PM
I don't know Brad, maybe I just start a 914 empire here and only have to deal with the humidity and none of the garbage associated with California. But it would be nice to be able to go to the track in the middle of the week and not have to rent the whole thing.
stock93 |
Sep 17 2003, 12:28 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
Brett,
Sounds like a plan to me (IMG:style_emoticons/default/smile.gif) Have you been down to berber raceway? I dropped you an email. John |
Brett W |
Sep 17 2003, 02:54 PM
Yes was there for the HSR race in March? Neat track. Just got back from Road Atlanta this past weekend.
seanery |
Sep 17 2003, 07:40 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Brett W,
That looks awful! Is it yours? Attached thumbnail(s) |
Carrera916 |
Sep 17 2003, 09:47 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
holy shit! (IMG:style_emoticons/default/blink.gif)
hope you didnt banged your head out of the driver side window! (IMG:style_emoticons/default/unsure.gif) j |
Brad Roberts |
Sep 17 2003, 11:38 PM
Brett/Brett ?? Moved to colorado Brett... now your in Alabama ?? Waaazzzuuuppp??
I know the car.. I have pics of it when it was done.. B |
stock93 |
Sep 17 2003, 11:43 PM
Now this engine really has me puzzled. I was checking valve clearances again an number one intake is at .009" I just recently adjusted the valves. I cant have even run it an hour since then. All I have been doing is trying to figure out where exactly the noise is comming front when running it. Last time I adjusted the valves I went back and double checked all my clearances.
John |
McMark |
Sep 18 2003, 01:15 AM
Not trying to be a smart ass, but are you sure you're at TDC for the correct cylinder when your adjusting the valves?
Lo-Fi Version | Time is now: 26th April 2024 - 03:09 AM |
