Wide Band Commander, Getto install, no really |
newto914s |
Apr 14 2006, 11:46 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
This is supposed to be super temperary. 10 minutes on, 10 off if need be. I'm going to use this to TRY to get some base reading on the d-jet. So if/when I start to make mods I can keep it all close to tuned.
Control box Attached image(s) |
DNHunt |
Apr 15 2006, 01:17 PM
I love that kind of engineering. There is nothing better than scrounging around for something that might work and then finding out it works pretty well. The uglier the better.
It may well be all you'll need but, I don't think there is anyway to be sure without comparing it to a known well calibrated WBO2 in a known good place in the exhaust to sample, on your engine. Barring that your reading will be ballpark which is really all any of us get from our setups anyway. I think itis generally felt that a well tuned D-jet cruises at 13.5, and WOT is 12.5. I'm not sure about idle. If you can use relative AFR for what you are doing I'd say you are good to go. If you need hard numbers then I think you need to find a way to calibrate the setup and that may be tough to do. Dave |
newto914s |
Apr 15 2006, 03:34 PM
So here's what I've got so far. I'm not sure how to get the time to chart into the graph(first time with excel, ever). This is from start up, thus the 18 reading before the engine is running. The steady even blips are me turning the AFR knob on the ECU. Each blip(11) is on click from the center CW. When it finally smoothed out the ecu is on Full rich, Can't turn the knob any farther. I've heard this is not a good setting, but the engine sounds good there. Then you can see in the graph as I slowly incress the RPMS(No WOT yet) and snap it closed.
Attached thumbnail(s) |
newto914s |
Apr 17 2006, 09:50 PM
Got it Tuned! I think (IMG:style_emoticons/default/wink.gif)
No matter what, it's way closer then it was. ECU is 3 clicks rich of center, and the pressure regulator is turned up some(no pressure gauge, so that could have been the problem). I also changed the throttle body to cure a bucking issue(faulty TPS sensor), and the car drives much much better. Most impotantly, I think it's running cooler. Multipule redlines and the CHT never went above 350. We'll see how it goes tomorrow on the highway in 5th, around noon. Wideband O2 sensors (IMG:style_emoticons/default/rocking nana.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 07:21 AM |
