Setting up DH and CR, Can someone check my math? |
swood |
Sep 18 2003, 07:35 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I mocked up the p&c's on the shortblock here's what Ive got:
Bore - 96mm Stroke - 66 Cylinder Head vol - 53cc Deck height (no barrel shim) - .047" (all the way around) CR calcs out to 8.75:1 If I add a .010" shim it will go to DH-.058" CR calcs out to 8.53:1 Opinions? I'm thinking that an 8.5:1 is suitable for this app. (1911cc). Oh, and I haven't lapped the heads yet now that I'm thinking about it. Should that be done prior to setting up the DH & CR? Also, I forgot to threadlock the flywheel bolts. Is this really necessary? If so, I take all that off again... Thanks guys, I'm getting there. |
Brad Roberts |
Sep 18 2003, 11:37 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
You should always run the plate.. the loctite is just a extra added layer of protection.
B |
Lo-Fi Version | Time is now: 16th May 2024 - 10:27 PM |
