Factory 6 speedo cable vs speedo cable from pelican |
olav |
Apr 29 2006, 06:16 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
I recently got a new speedo cable from PP with intentions of replacing my old one that needs it. I'm kind of hesitating because the original one has a 19mm flange hex for a wrench while the relacement is a twist on to tighten with your hand and a visegrip or something. Also, the rubber cover covering the cable flange connection is quite different. I was wondering if this matters at all as far as factory goes or if I can get the same cable connector to-the-speedo-angle-drive still anyway? I can keep the old cable just for posterity anyway. Seems some parts are kind of morphing over time a little bit. But the parts that wear out seem to be far game to replace without fear of not being "original" I guess. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:34 PM |
