914 Tool Kit info, Correct for a 1973-1974 914-4 cyl. kit |
TJB/914 |
Apr 30 2006, 09:53 AM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Lets start a list of correct 914 Tool Kit parts.
Here's one for a 1973 & 1974 914-4 cly. car (Comments please to confirm??) Tom Attached thumbnail(s) |
TJB/914 |
Apr 30 2006, 11:11 AM
Tool Kit for a 914-6
Tom Attached image(s) |
sixnotfour |
Apr 30 2006, 12:30 PM
914 Wizard Group: Members Posts: 10,414 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the 4cyl. kit , did it come with a shaft to use with the plug socket or are you intened to use the screwdriver shaft?
ClayPerrine |
Apr 30 2006, 12:34 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
sixnotfour |
Apr 30 2006, 01:01 PM
learn somethin everyday thanks
TJB/914 |
Apr 30 2006, 02:59 PM
Here's somthing to think about when at a swap meet. Look for trade material pieces (see pics) to help our 914-brothers out.
Next time in the office supply cabinet look for BLACK rubber bands that are about 4" long 5mm thick & about 1/8" thick. Thats usually a hard item to find in a tool kit. Tom BTW Nothings for sale (only trade material to my CW sicko friends) Attached thumbnail(s) |
TJB/914 |
Apr 30 2006, 03:01 PM
Rubber Band picture dimensions
tod914 |
Apr 30 2006, 04:57 PM
Tom whats the funcion of the that clip in the 4 kit?
TJB/914 |
Apr 30 2006, 07:37 PM
Tod,
You mean that thin U-shaped wire with hooks on each end (picture #1)?? It's to pull off hub caps. On plain wheels with hub caps each hub cap has (2) little holes on the outside diameter of the hub cap. The U-clip wire is inserted into the holes, then pulled to remove the hub caps. Tom |
JeffBowlsby |
Apr 30 2006, 08:08 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Tom the 74 kit did not have the bag with the tie, only the thin black plastic polyethylene bag.
I find it odd but my 74 car has that hubcap puller tool too, but in 74 none of the 914s came with hubcaps, they were either alloys or the cross-style steel rims. |
davep |
Apr 30 2006, 08:36 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yeah, I'd say the black plastic bag for 1974 and the leatherette bag for 1973. Very early ones got the coarse weave bag. You didn't get the plastic and the leatherette bags together in one kit.
914runnow |
May 1 2006, 05:21 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Kool a 914 site for GeeKs like me...Horray!!
70-71-72-Very early 73's had that vinyl tie bag.. (I think there was smooth grey and a black pattern) And production date 12/73 or so had the vinyl 'Flip Bag'...(that not much would fit into)... Earlier tie bag kits had the pliers also included with them.. Seems the spark plug wrench and small bar for your 73 and later kit is missing..... The six kits appears to be on the money.... About 6 years ago from A Porsche dealership, I bought a '914 kit' that was a Supercede #, and it was 416.00$ And was in between a 6cyl and 4 cyl kit for items enclosed..Sorry no pics at this time... |
Poor-sche Lover |
May 1 2006, 09:01 PM
Member Group: Members Posts: 67 Joined: 25-November 05 From: SE Kansas Member No.: 5,190 |
Why was a rubber band even included in the kit? From looking at the pictures, it seems more like a MacGyver kit to get the car home. "If we wrap the rubber band around the screw driver, and hook up the paper clip to the battery, we can jump across the leads to . . . " But seriously, why a rubber band?
TJB/914 |
May 1 2006, 09:16 PM
The rubber band was used around the entire outside of the black plastic bag to keep the tools from falling out.
Remember the black plastic bag was for the 1974 model year. Tom |
sixerdon |
May 2 2006, 07:27 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
I've got the plastic bag for my '75.
Tom, what is the make up of the "6" tool kit showing the spare fuses? It looks like a vacuum pack kit in the picture. The ones I've see were loose in a small clear plastic bag. Can you confirm? Thanks, Don |
Pat Garvey |
May 2 2006, 09:29 AM
My '72 tool kit, hermetically sealed - so no photo, contains:
Towing eye Combination screwdriver Hub cap removal tool 8x13 mm open end wrench Socket for wheel bolts Socket for plugs Bar for wheel bolt socket Bar for spark plug socket Vinyl, strap-tie bag My bag is light brown & the only one I've seen in that color - all the others have been gray. Just proves my belief that when a parts bin was empty, they grabbed whatever was handy. The kit is as-delivered & I am the original owner. |
tod914 |
May 2 2006, 07:39 PM
Pat could you post some pictures of your car at some point? Looks incredable in your avatar. (IMG:style_emoticons/default/chowtime.gif)
JeffBowlsby |
May 2 2006, 07:46 PM
tod914 |
May 2 2006, 07:54 PM
Very Impressive car ..... but is that a bosch blue coil i see in the engine bay with a cadium plated holder instead of black? -.5 of a point Pat (IMG:style_emoticons/default/happy11.gif)
BS Chairman |
May 2 2006, 08:21 PM
Member Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 |
I've got the plastic bag for my '75. Tom, what is the make up of the "6" tool kit showing the spare fuses? It looks like a vacuum pack kit in the picture. The ones I've see were loose in a small clear plastic bag. Can you confirm? Thanks, Don Don, Thats my tool kit (6) and yes they are vacuum pack fuses only because thats what I had to put in it and make it complete. I have'nt seen a factoy kit so I did my best from pics! Close to factory as to take 2nd at parade 2005. Gary BS Chairman |
Lo-Fi Version | Time is now: 30th April 2024 - 02:53 PM |
