Where does this mysterious little light go?, fell out of center console while reconnecting stereo |
BigDBass |
May 3 2006, 05:00 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I was digging around under the dash to find a wire that'd been disconnected from the stereo, and this little light bulb sorta appeared. It lights up just fine, but where do I poke (IMG:style_emoticons/default/poke.gif) it back in?
914-8 |
May 3 2006, 05:04 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
looks like for the ventilation slide control panel
May 3 2006, 06:35 PM
looks like for the ventilation slide control panel (IMG:style_emoticons/default/agree.gif) one of the two lights for the dash-vent-controls ... they slide into a small socket on each side and make ground through the assembly ... (IMG:style_emoticons/default/smile.gif) Andy |
BigDBass |
May 3 2006, 08:23 PM
Ok, I'll see if I can get it back in there without taking much apart. Otherwise I'll just poke it out of the way until it fits into a "while I'm in there" situation! (IMG:style_emoticons/default/biggrin.gif)
Thanks for the answer! |
BigDBass |
May 4 2006, 10:31 PM
Trivial observation: I discovered tonight that moving the Fan slider changes the brightness of the little light... (IMG:style_emoticons/default/ninja.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 02:47 PM |
