stephen7 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-March 06 From: seattle wa Member No.: 5,663 ![]() |
where can you get the warning light that replaces the factory speedo?
thanks steve |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/blink.gif)
Huh? You want to replace the speedo with one big light? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/icon_bump.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,020 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Steve,
try the racing catalogues. also, be aware that without a "hood" or shade you loose some visibility. I removed my un-hooded light in my old car because half the time I couldn't see it due to sun glare. new car had this 1) for alternator belt 2) for oil pressure no way you can miss seeing these: Attached thumbnail(s) ![]() |
roundboy914 |
Member ![]() ![]() Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 ![]() |
I have the red one in my street/track car for oil pressure (after i lost an engine due to a blown oil line to a front oil cooler). On the street, i have to leave the cover on - it is way bright without the cover.
I like to blue one for the alternator - mine has slipped off before, and there is no way to see the samll light out on the track. At any rate, the red one works great, just mount it on the steering column. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/blink.gif) Huh? You want to replace the speedo with one big light? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/icon_bump.gif) go look at 911RSR (IMG:style_emoticons/default/smile.gif) a fatty Oil Pressure warning light took up that area of the clock...... |
KaptKaos |
Seemed like a large light to me, but what do I know, I don't race.
More of a bump since it was off the front at the time. |
brant |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,902 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
There is an easy solution for the CSOB NARP owner. You don't have a working parking brake on your race car, right? Simply switch the wires around so the big red parking brake light becomes the Oil Warning light. Voila. (IMG:style_emoticons/default/smilie_flagge24.gif)
stephen7 |
thats a smart idea. The collective lot of you are brilliant. steve
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I used nice large LED lights purchased from AW Direct, a truck & towing supply co.
The amber light is a cooling system warning light since my cooling system is belt driven. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 30th July 2025 - 10:26 PM |
