jd66921 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 ![]() |
Hi,
I'm driving my "new" car home from California. It's running... A few problems - missing badly, but we changed the fuel filter and hopefully fixed that. The latest is an idle problem. It's a 1.8 L-Jet, stock configureation. On deceleration it's dropping through the bottom and stalling most times. Idle hot seems too low as well. I don't want to try a full repair, but I'm wondering if someone can show me where the idle adjusment screw is. I'm hoping I can get the idle up far enough so I don't have to heel and toe it all the time. Seems that I have seen a picture of that screw, but can't find it right now! Any help would be much appreciated!! 400 miles down, 1200 to go! Thanks, Jeff |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
seems like its running a tad lean.
I would venture a guess to say its a vac leak somewhere. That idle should be dead on x rpm. L-jet kinda drove me mad looking for airleaks, and once I thought I had them all taken care of, engine blows up from being too lean. b |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,208 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The idle screw is on the throttle body. You can access it from the top, IIRC, on a 1.8 liter.
--DD |
Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
If you are somewhere you can get the vacuum hoses, you should just replace them all, if they are all new, you should not have to guess which one is leaky, L jet is sensitive to the vac leaks..., how is the ignition timing?
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Check your oil filler cap seal. No, I'm not joking. It is part of the system.
Good luck, let us know. |
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
like the good Dr said the oil filler cap seal is very important with the L jet. if it does not seal all the vacume is screwy every where else.
Bernie |
Lo-Fi Version | Time is now: 30th July 2025 - 12:37 PM |
