911 to 914 gauge transplant, (self explanitory) |
Aaron Cox |
Feb 23 2003, 07:54 PM
I want to put an early 911 combo gauge in my teener to give me a heads up on oil pressure. To do this i would need a 911 fuel / oil level combo, and the gauge insert and sender for the 911 oil pressure. Then instead of oil level, i woul have an oil pressure indicator correctly labeled "oil" (best ya could do). Is it possible to use a 911 oil pressure sender on a 914/4 block? (IMG:style_emoticons/default/huh.gif) also, can i use my vdo dual sender, (operates dash light and another vdo cockpit gauge-used for engine break in process) Is all this possible?
Lo-Fi Version | Time is now: 20th May 2024 - 02:23 AM |
