Took the Turbo off my new motor..., I Think I am going to have some turbo lag.... |
ClayPerrine |
May 17 2006, 09:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
But LOTS of Boost!!!
bd1308 |
May 17 2006, 09:29 PM
I wonder if those vanes would even MOVE...
what the hell is that thing? b |
Thack |
May 17 2006, 09:35 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
Does that thing belong to an industrial engine? Gas compressor?
messix |
May 17 2006, 09:44 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
can you say very large marine engine?
Joe Bob |
May 17 2006, 09:51 PM
Bet it's for a stationary engine of some kind.....
So.Cal.914 |
May 17 2006, 10:37 PM
Maybe you could hook it up with flexable lines and tow it behind on a trailer.
Ponys to compensate for the trailer should not be a problem. (IMG:style_emoticons/default/smoke.gif) |
Brian Mifsud |
May 17 2006, 11:02 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
I've got a gearbox for you if you want to put that turbo back on.. it's kinda torquey...
mongrel-gs |
May 18 2006, 08:22 AM
Member Group: Members Posts: 55 Joined: 29-November 04 From: Baltimore, MD Member No.: 3,194 |
If the suby conversion ever runs into problems, I was thinking about this. I think I'll have to cut the trunk to still use the engine bay radiator though.
(IMG:http://www.bath.ac.uk/~ccsshb/12cyl/rta96c_crank.jpg) Big Diesel |
jsteele22 |
May 18 2006, 10:02 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
If the suby conversion ever runs into problems, I was thinking about this. I think I'll have to cut the trunk to still use the engine bay radiator though. (IMG:http://www.bath.ac.uk/~ccsshb/12cyl/rta96c_crank.jpg) Big Diesel Be careful : if you do a swap like this, I don't think the PCA will let you race in their events.... |
iamchappy |
May 18 2006, 11:52 AM
I wonder if it belongs to one of these.
Thack |
May 18 2006, 03:14 PM
looks like oilfield equipment. I seee a large canister oil filter case in the background.
Brian Mifsud |
May 23 2006, 02:18 PM
Ship Engine, 100,000 HP at 90 RPM, 100RPM redline.. you should see the cylinder heads!! (lost link awhile ago..)
Lo-Fi Version | Time is now: 14th May 2024 - 08:55 PM |
