Street cam recommendations for 2l dual webers, need lift, duration and mfg recommendations for dual webers. |
alremley |
May 18 2006, 09:00 AM
Newbie Group: Members Posts: 32 Joined: 25-September 05 From: Lancaster, KY Member No.: 4,861 |
Planning to have my 2liter with weber 40 idfs spec'd out. Want a good cam for daily street use. Car will be driven mostly in the 2000 to 3000 rpm range with occasional back road jaunts up to 4500 rpm.
Would like to hear of your satisfied selection. |
szuccaro |
May 18 2006, 10:25 AM
ZUKE Group: Members Posts: 200 Joined: 27-June 03 From: Cameron Park, CA Member No.: 862 Region Association: Northern California |
My setup is similar to yours: 2.0L w/big bore kit, dual weber 40's, street fun mainly (occasionally I push it) and I am running a mild "Web" cam. This setup works great for me. Steve
Attached thumbnail(s) |
JmuRiz |
May 18 2006, 11:05 AM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I run a similar setup, I can look up the specs for my webcam as well. I think mine is relatively mild in profile. Hopefully Jake will pipe up here and give his thoughts, as he's the guru.
Let me know and I can try to find the paper from my car's PO. |
Joe Ricard |
May 18 2006, 11:17 AM
86a .435 lift and 270 duration
mine is 86b but has some other designation. .500 lift and 300 duration ported 2.0L heads Tangerine header and 32 vents in 40IDF's It runs good. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:03 AM |
