MSD help |
MSD help |
watsonrx13 |
May 20 2006, 04:14 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I attempted to install the complete MSD ignition system that Andy sold me, but I didn't have any luck. The engine is a 2.0l with dual 40 IDF webers, with the Webcam 86a cam (for carbed engines).
Here's a list of the parts: MSD box Blaster coil MSD distributor w/spark plug wires adapter cable MSD tach adapter NGK B7ES spark plugs with the metal caps attached Here's how I installed everything: 1. Andy had already attached the MSD box to an aluminum plate, which I attached to the battery, where the FI brain use to go. 2. Removed the blue coil and installed the MSD coil. 3. Replaced distributor with MSD distributor. 4. Attached the MSD tach adapter to the aluminum plate 5. Installed the new spark plugs and wires Here's how I attached the wires: 1. Purple and Green wires from 'back side' of MSD box to the adapter cable, then this cable was attached to the MSD distributor. 2. Orange and Black wires from the 'front side' of MSD box to the MSD coil. Orange to + (positive) and Black to - (negative). 3. Red and Black wires from the 'front side' of the MSD box to the battery. Red to + (positive) and Black to - (negative). 4. Red and White wires from the 'front side' of the MSD box to the MSD coil. Red to + (positive) and White taped off and not used. 5. Black and Black/Purple wires from the wiring harness to the MSD coil. Black = (positive) and Black/Purple to - (negative). Well I tried to start the car but there was no spark at the plugs. I checked the spark out of the coil, but there wasn't any there either. I don't understand how to connect the MSD tach adapter and where the wires hook up. After attempting to get the car started, and failing, I reinstalled the old blue coil, distributor, plugs and wires. What did I do wrong and how can I check if I 'fried' any of the electronic systems? Any suggestions, comments and pictures will certainly be accepted and appreciated. -- Rob |
Trekkor |
May 20 2006, 04:52 PM
I don't have my diagram in front of me, but I believe the original coil wires from the harness go to the MSD.
Then the black and white go to the coil alone. You should only have two wires on the coil. I'll hunt for the diagram. KT |
Trekkor |
May 20 2006, 05:05 PM
This will do it!
KT Attached image(s) |
Porsche Rescue |
May 20 2006, 05:06 PM
I have MSD manual which covers all sorts of distributors. The two diagrams below appear to be the only ones for an MSD distributor. The first one appears to be the only one with a purple (violet)/green harness. Let me know if these don't help and we can try some others.
Edit: Looks like Trekkor has the same book. Now you have 3 to choose from, but I see no purple wire in Trekkors. His is what I used on a six with Pertronix. Attached image(s) |
Trekkor |
May 20 2006, 05:07 PM
hold it!!
there is a page in the instructions for using an MSD dizzy. One moment... |
Porsche Rescue |
May 20 2006, 05:12 PM
After looking at your diagram, I think you want the black from harness (ignition) connected to the red to MSD box, rather than both connected at the coil. The purple/black wire is to your tach and connects to the tach output on the box, not to the coil. Only the orange and black from the box go to the coil.
Trekkor |
May 20 2006, 05:14 PM
you're fast...
watsonrx13 |
May 20 2006, 05:27 PM
Thanks for the info guys. I don't have the parts with me right now, but I'm going to the shop to pick them up, then I'll post more pictures and/or drawings to verify that I have everything ready to be hooked up tomorrow....
-- Rob |
watsonrx13 |
May 20 2006, 06:52 PM
OK, I'm back from the shop with some more pictures......
The tach adapter has red and white wires, with 2 wires each off of them..... So which wire, red or white, does the black/purple (from the wiring harness) attach to? And do I tape the other wire up so that it isn't used? -- Rob |
May 20 2006, 07:06 PM
Resident German Group: Admin Posts: 41,601 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The tach adapter has red and white wires, with 2 wires each off of them..... you want the basic setup to run before you try to make your tach work with it ... simply follow the MSD installation instructions (without the tach adapter) and yopu should be good to go ... (IMG:style_emoticons/default/smile.gif) Andy PS: i *thought* i had added the MSD instructions to the box. did i forget to send them? |
watsonrx13 |
May 20 2006, 07:21 PM
No Andy, I have the instructions, but there are WAY TOO MANY diagrams for me to understand. I got most of it together correctly, but I was having difficulty with the red wire coming out of the MSD box, grouped with the taped off white wire.
If I can get the final connection for the tach adapter answered, I'll connect that up after I successfully get the engine running.... -- Rob |
Porsche Rescue |
May 20 2006, 07:47 PM
None of the diagrams above even show the tach wire. It is one wire, connected to a male spade terminal located on the box where it says "tach output" on the diagram.
watsonrx13 |
May 20 2006, 07:53 PM
OK, I'll check the MSD box tomorrow.
Now, what is the small square red box between the distributor and the coil? I thought that was the tach adapter.... |
Porsche Rescue |
May 20 2006, 07:56 PM
Gotta leave that one to Andy, beyond my experience.
watsonrx13 |
May 20 2006, 07:58 PM
Then obviously I won't need it for this installation.....
Thanks again for all of your help, I'll post tomorrow the successful results.... (IMG:style_emoticons/default/biggrin.gif) |
jim_hoyland |
May 20 2006, 09:19 PM
Get that VIN ? Group: Members Posts: 9,254 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The little red box is the tach adapter. See: http://forums.pelicanparts.com/showthread....on&pagenumber=1
jim_hoyland |
May 20 2006, 10:02 PM
Pic>>
Joe Bob |
May 20 2006, 10:14 PM
A diode MAY be needed in the D+ circuit....1 out three in my experience....the engine may run on after the ignition is shut off....
Joe Bob |
May 20 2006, 10:15 PM
In the alternator to the alternator light in the dash....
watsonrx13 |
May 21 2006, 08:09 AM
OK, here's the lastest and hopefully final wiring diagram:
1. Purple and Green wires from 'back side' of MSD box to the adapter cable, then this cable is attached to the MSD distributor. 2. Orange and Black wires from the 'front side' of MSD box to the MSD coil. Orange to + (positive) and Black to - (negative). 3. Red and Black wires from the 'front side' of the MSD box to the battery. Red to + (positive) and Black to - (negative). 4. Red and White wires from the 'front side' of the MSD box to the MSD coil. Red to + (positive) and White taped off and not used. 5. Black and White wires from the 'front side' of the MSD box to the MSD tach adapter. Black to 1 of the red wires and White to 1 of the white wires. 6. Black and Black/Purple wires from the wiring harness to the MSD tach adapter. Black connectes to 1 of the red wires coming from the tach adapter and Black/Purple connects to 1 of the white wires coming from the tach adapter. |
Lo-Fi Version | Time is now: 17th April 2024 - 11:08 PM |
