MSD help |
MSD help |
watsonrx13 |
May 28 2006, 08:46 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
mounted mine on the pass side firwall. short connections to coil and battery Aaron, yep, that's where I mounted mine. I'll post pics tomorrow, left the camera at the shop... Joe, I'm hoping to use the current tach, it's brand new from the new car part's stash.... -- Rob |
rhodyguy |
May 29 2006, 08:01 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,070 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
stock tach, works fine. daveh did a good job when i purchased this setup from him, and he handled the wiring aspect. (IMG:style_emoticons/default/biggrin.gif) install, set timing, haven't touched it since, spring 05'.
k Attached image(s) |
bob174 |
Jun 2 2006, 11:41 AM
Member Group: Members Posts: 125 Joined: 9-January 03 From: League City, TX Member No.: 122 |
I'm doing the MSD/tach adapter installation right now also. Is the tach wire the wire that's on the negative terminal of the coil?
Porsche Rescue |
Jun 2 2006, 01:18 PM
Factory tach wire is always black with a purple tracer.
bob174 |
Jun 2 2006, 01:21 PM
Porsche Rescue |
Jun 2 2006, 04:56 PM
I believe so, but not certain. All I know is it goes to the coil but mine now goes to my MSD so I can't look to be sure.
watsonrx13 |
Jun 2 2006, 06:31 PM
Factory tach wire is always black with a purple tracer. Ok, and it goes to the negative coil terminal, right? In the original configuration I mean. Yes Bob, the black/purple tach wire originally went to the negative side of the coil... BTW, I just received the diode in the mail today, from MSD. I'm going to wire this in and hopefully finally get the tach to work correctly... Here's a diagram of how I'm going to wire everything together... |
watsonrx13 |
Jun 8 2006, 08:20 AM
Lo-Fi Version | Time is now: 30th April 2024 - 11:57 PM |
