| DNHunt |
May 20 2006, 08:10 PM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I couldn't find Mile's drawing of a cam (it magically made everything make sense to me) so, I decided to try my hand at it.
First, jack the car up so it assumes the usual and comfortable position of a 914. Resting securely on jackstands. I won't get under it without jackstands cause the thing jumps off of jacks. I have a dented long on the driver's side and a dented rocker panel on the other side to prove it Dave Attached image(s)
DNHunt My shot at explaining valve adjustment on a 4 pot May 20 2006, 08:10 PM
DNHunt Get under the car and remove the valve covers. I... May 20 2006, 08:14 PM
DNHunt Here's what you will see. The rocker assembly May 20 2006, 08:15 PM
DNHunt The whole process works because the flat aircooled... May 20 2006, 08:25 PM
DNHunt As a practical matter lock a road wheel so it will... May 20 2006, 08:33 PM
DNHunt I start by watching #2 exhaust and turing until it... May 20 2006, 08:37 PM
DNHunt On the opposite side of the engine #4 exhaust valv... May 20 2006, 08:47 PM
DNHunt Next rotate the engine until #2 intake is open. Se... May 20 2006, 08:52 PM
DNHunt Adjust #4 intake cause it is on the valve seat and... May 20 2006, 08:54 PM
DNHunt Rotate until #1 intake is open. May 20 2006, 08:55 PM
DNHunt Adjust #3 intake May 20 2006, 08:56 PM
DNHunt Rotate a gain until #1 exhaust is open. May 20 2006, 08:57 PM
DNHunt Adjust #3 exhaust May 20 2006, 08:58 PM
DNHunt Now block the other wheel so you can check the opp... May 20 2006, 09:00 PM
DNHunt Check #4 exhaust for full openning May 20 2006, 09:01 PM
DNHunt Adjust #2 exhaust May 20 2006, 09:02 PM
DNHunt Check #4 intake for full open. May 20 2006, 09:03 PM
DNHunt Adjust #2 intake May 20 2006, 09:04 PM
DNHunt Ditto for cylinder #3 intake and exhaust. Rotate u... May 20 2006, 09:06 PM
DNHunt Adjust #1 intake May 20 2006, 09:07 PM
DNHunt Check #3 exhaust. May 20 2006, 09:07 PM
DNHunt Adjust #1 exhaust. May 20 2006, 09:08 PM
DNHunt Tighten everything and check the valve cover gaske... May 20 2006, 09:10 PM
DNHunt I suppose this is a bit of urban myth but, I'v... May 20 2006, 09:12 PM
mcbain77 Fuchin Classic. May 20 2006, 09:14 PM
elwood-914 Great Job Dave!! Good luck on your trip ne... May 20 2006, 10:14 PM
Aaron Cox very nice. ive always done it like this. May 20 2006, 10:58 PM
newto914s Classic for sure! Thanks for the cam drawing, ... May 20 2006, 11:47 PM
lotus_65 thanks!
it couldn't have come at a better ... May 21 2006, 05:34 AM
Spoke I like the cam drawing, saves me from reading.
Ou... May 21 2006, 06:08 AM
rhodyguy very nice dave. you and jerry have a fun drive.
k May 21 2006, 07:05 AM
scottb dave,
very nice write up.
what header are you ru... May 21 2006, 11:35 AM
Tobra You could never get nice pictures like that with t... May 21 2006, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:28 PM |
