Need this dimension..please :), Front /4 rotor |
Mueller |
Sep 26 2003, 09:58 AM
'74 (not sure if year makes a difference or not???)
My rotor is turned down for my Vanilla Rice (IMG:style_emoticons/default/MDB2.gif) rims and I need this dimension for a stock rotor.... thanks Attached image(s) |
fiid |
Sep 26 2003, 10:30 AM
I measured the inside diameter of my mahles and it comes out at ~55.3mm Couldn't measure the hub because of the bearing grease hump :-(. I would bet it's 55mm
From a 73. |
Mueller |
Sep 26 2003, 10:43 AM
thanks.....
mine measure 73mm after machining, I think you measured the hole for the centercap, not the "hubcentric" hole ???? (IMG:style_emoticons/default/smile.gif) |
JFJ914 |
Sep 26 2003, 12:19 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
How about 78.75 MM ? Squinting with my good eye and NSK caliper...........
John Jentz |
URY914 |
Sep 26 2003, 12:22 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,863 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Mike,
What are you doing with those Wilwood calipers? Paul |
Mueller |
Sep 26 2003, 12:23 PM
using them as a foot rest (IMG:style_emoticons/default/smile.gif)
they are still sitting in thier boxes (IMG:style_emoticons/default/sad.gif) I'm working on a "real" project right now, LOL |
Brad Roberts |
Sep 26 2003, 12:24 PM
4 lug vented rotors ??
B |
fiid |
Sep 26 2003, 03:57 PM
QUOTE(Brad Roberts @ Sep 26 2003, 10:24 AM) 4 lug vented rotors ?? B MMMMMM. Sounds tasty. Thats plus BMW calipers might make for some serious faceplant. Fiid. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:16 AM |
