Wrap That Sucker, Solution for the battery Hell Hole. |
GTPatrick |
May 23 2006, 08:13 PM
Member Group: Members Posts: 245 Joined: 8-September 05 From: Memphis, Tn. Member No.: 4,768 Region Association: None |
There is a soft insulated container for batteries in Fieros that's available at the " Fiero Store " in Ct. . It's designed to help keep the heat away from a battery in the engine compartment of the Fiero similar to the 914's location/problem . Also , Cadillac has one available for use in its CTS models. These are soft walled containers with a lid that keep the heat away from the batter and absorb any battery acid that leaks.
So far the one in my '03 CTS hasn't given me any problem so t should work in the 914s . (IMG:style_emoticons/default/idea.gif) It's worth a look at it to see if it's a possible solution to the battery leak problem that are in 914s. (IMG:style_emoticons/default/happy11.gif) GTPatrick (IMG:style_emoticons/default/aktion035.gif) |
May 23 2006, 09:48 PM
It's worth a look at it to see if it's a possible solution to the battery leak problem that are in 914s. one word .... "optima" ... no more leaks no more ... (IMG:style_emoticons/default/smile.gif) Andy |
Eric_Shea |
May 23 2006, 09:51 PM
QUOTE no more leaks no more Been spending too much time with Slits too much. |
Lo-Fi Version | Time is now: 15th May 2024 - 05:27 AM |
