Transmission Fluid Question, How much does it take to fill? |
ptravnic |
May 25 2006, 06:07 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Filled mine for the first time, will ever (been driving for 10yrs) and it gulped almost 3qts... Needless to say, the sloppy tail shifting became less sloppy (albeit still a tail shifter).
How manay qts fill up an empty tranny? |
jr91472 |
May 25 2006, 06:14 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Someone with the Haynes manual handy can give you the exact quantity, but just short of 3 qts is right. Just keep going until it drips out of the fill hole and your good.
(IMG:style_emoticons/default/beer.gif) |
So.Cal.914 |
May 25 2006, 12:23 PM
The trans holds 2.6 qts, sounds like it was empty. Looks like you got off cheap.
(IMG:style_emoticons/default/smoke.gif) |
ptravnic |
May 25 2006, 01:07 PM
Mine must have been close to empty b/c I put in between 2 & 3 qts. Granted, I had the right side jacked up so I might have overfilled it a bit by the time it got full... Lucky me!!! (IMG:style_emoticons/default/boldblue.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 05:55 PM |
