2.0 timing marks |
2.0 timing marks |
srb7f |
May 27 2006, 07:39 PM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
Stupid question...the notch in the 1975 impeller fan is the 27 degree timing mark, correct? I'm just making sure that it's not the #1 TDC mark.
type47 |
May 27 2006, 08:16 PM
i think TDC is a circle or oval and 27 degrees is a groove or notch in the fan.
Hoss |
May 27 2006, 09:42 PM
Member Group: Members Posts: 113 Joined: 24-January 06 From: Del Mar, CA Member No.: 5,465 |
Steve,
Have you read the timing information that the Bird Board has in its technical article section? I hope it helps. Cheers, Hoss |
Lo-Fi Version | Time is now: 15th May 2024 - 09:14 PM |
