engine problem |
engine problem |
STP |
May 31 2006, 06:48 PM
Member Group: Members Posts: 64 Joined: 29-January 06 From: Alameda, CA Member No.: 5,497 Region Association: Northern California |
So, My 914 has been sitting at my grandmother's house for the last 2 months and after finally being able to work on it again I've run into a few problems.
Firstly, none of my gauges are working. Not the tach, not the fuel gauge, nothing. Second and more importantly, I was checking and adjusting the timing on the dizzy according to the PP article, and the engine started making this knocking noise. I'm not sure what it is. At first I thought it was preignition, Seeing as I advanced the timing, but it sounded mechanical, like lifters maybe but really loud. Then I thought because it hadn't been started in a while that maybe I should have primed the oil pump. But, like I say, I have no idea so far. I did a compression test on it before I put it away and one of the cylinders was about 40psi lower than the others. So my questions are: What could the gauge problem be? I dont even know where to start so even that would be helpful. What's the most likely answer to the knocking problem? What do I do about the low compression? I thought 40psi was kinda high. Will I need to get a valve job? Could this be related to any of the other problems I'm having? Compression: 140 120 120 100 I have a 73 2.0 with Webers (40s) if this helps. Thanks for all your help, Sean |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 AM |
