dizzy line of questioning |
geniusanthony |
Jun 2 2006, 11:23 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
tomorrow I will be rebuilding my webers and replacing distributor with I don't know.
I have a choice between a 009 and 050 distributor, i hear the 050 has a more rapid advance curve. the engine as it sits now is a 1.7 with a big bore (96mm) and two weber 40 IDF's. So, which distributor would be best suited.... |
McMark |
Jun 2 2006, 11:52 PM
The 009 sucks, so I'd go with ANYTHING else. 050 should be good.
geniusanthony |
Jun 3 2006, 12:23 AM
why does the 009 suck, isnt that the standard dist. for a carbed car by the way it has the standard cam...the fuel injected one
ALso should I get a new coil at same time?..the current one looks pretty old |
JPB |
Jun 3 2006, 07:00 AM
I'm going with the Compufire DIS-IX distributerless system for the 009 distributor. It wallups 65,000 volts and only cost 200$ off the shelf. Curls my hairs, tickels my balls and makes me schmit in my overalls.
(IMG:style_emoticons/default/beer3.gif) Mornin Java jargon. |
JoeSharp |
Jun 3 2006, 07:11 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The 009 doesn't have much advance and it comes on late. Set them on full advance and the motor stumbells at low speeds.
:PERMAGRIN: Joe |
Cap'n Krusty |
Jun 3 2006, 07:36 AM
The 009 has about 17 degrees of advance, TOTAL! The 050 has 30-32 degrees. If you use the 009, you have to set the static (base) timing at 12-15 degrees, giving you a difficult time getting the idle down, among other things. No brainer, IMO. The Cap'n
Lo-Fi Version | Time is now: 4th June 2024 - 07:24 AM |
