Modified flywheel, messing around on a cnc at work |
KevinP |
Jun 10 2006, 04:28 PM
Member Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 |
I don't think I would install a lightened flywheel with out doing the entire rotating mass balance. I think all should include crank,piston,pins, fan; ect... If your gonna use this on a DD I wouldn't go less than about 15 lbs. Whats the real benifit on running a lighten FW. I would think the quick revs only. Whats the down side? Float the valves on a missed shift. What about the loss of TQ and driveabilty. Just my 02 cent, but I like it when we go outside the box. Thats why I hang out around here!!!
You guys will never stop letting me learn- Thanks for that...... KP out |
muddboy |
Jun 10 2006, 05:08 PM
Member Group: Members Posts: 91 Joined: 10-November 04 From: Anahiem, CA Member No.: 3,085 Region Association: Southern California |
um no.... why do you think I do it for a living as far as weights... the 3 used ones i have are around 16.5 to 17lbs before I ran the program. |
muddboy |
Jul 11 2006, 10:20 PM
just an update I surfaced the test flywheel and I am going to Ballance it soon.(IMG:https://www.t-mobilepictures.com/photo/photo06/a7/9b/bef1a07fa25b.jpg?tw=305&th=228&_rh=9dxzrqcu7eyw8incijqzpw8bo)
Brett W |
Jul 12 2006, 01:29 AM
I machined mine back in the day down to 11 lbs and ran it on a daily basis with a Six puck solid hub disk. Made a grabby as hell clutch but if you learned to drive it and slip the clutch just a little it wasn't that big of a deal.
The one I made, I machined the normal wieght off the backside and then layed it face down on the bed of a mill. Then came in and carefully milled all of the area on either side of the dowel pins. I did this on four sides. All done without a rotary table. It was ugly but it worked well. Never had a problem. Joe Ricard has it now. I think he was little ill that it was as ugly as it was, but it worked great. You should be able to get it down to around 8lbs without too much work. |
Joe Ricard |
Jul 12 2006, 05:04 AM
Nope. Hey I got a extra flywheel if you want another one. Where do I send it? Yes I have Brett's wheel. it's nice and actually pretty sexy. It will be going in my new Red Neck Racer motor. |
turboman808 |
Jul 12 2006, 05:45 AM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Wish I had machinery like that to use (IMG:style_emoticons/default/sad.gif)
Rog914 |
Jul 12 2006, 06:26 AM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
Could it be possible to machine a 911 (225 mm) clutch & pressure plate to fit a 914 flywheel? For high HP engines.
Ralph |
brant |
Jul 12 2006, 08:06 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I just finally got my tranny pulled a week or so ago, and took out my old flywheel.
here she is, 10lbs: Attached thumbnail(s) |
Dad Roberts |
Jul 12 2006, 04:47 PM
Member Group: Members Posts: 224 Joined: 1-January 03 From: Ontario,Ca. Member No.: 70 |
I lightened my first VW flywheel on a disc brake lathe (IMG:style_emoticons/default/biggrin.gif) . Damn......that was a LONG time ago (68). Balancing? Hey, as an edumacated teenager, if you took the same amount off all the way around.....it's STILL balanced, right?? (IMG:style_emoticons/default/biggrin.gif) I put that puppy in a 58 Rag with a 63 40 horser. Hang on brother! Oh yea.....I agree with you Mikey, they are sexy (IMG:style_emoticons/default/thumb3d.gif) . Sorry I missed ya last week Mikey...................Dad (IMG:style_emoticons/default/driving.gif)
Brando |
Jul 12 2006, 10:17 PM
I seem to now have 2 extra flywheels... any chance I can get some of this cool lightening done to at least one of them? 12.5->13lbs of course. (IMG:style_emoticons/default/smile.gif)
muddboy |
Jul 13 2006, 07:46 PM
I just ran a newer program on the cnc today... came out at 12lbs. Yes I can get it lighter if you want. Looks like we will be charging 150 to lighten it, and 60 for the surface. Also if youre intrested found the parts to modify the flywheel to take a double clutch pack(pricey though).
I am looking to get extra flywheels(those of you who offered) so I can get them ready to trade out for ppl who want a fast turn around. |
brant |
Jul 13 2006, 10:02 PM
how much for the 6lb version:
Mueller |
Jul 14 2006, 04:09 AM
Brando |
Jul 14 2006, 01:23 PM
$150 to lighten and balance? Shaweeeeet. (IMG:style_emoticons/default/thumb3d.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 12:56 PM |
