Help with part number 90135101204, Deep 6 or not |
Heeltoe914 |
Jun 9 2006, 04:20 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Can someone post info about this rim. Is it a deep six or just a run of the mill six. What cars did Porsche add this rim to? Thanks. 90135101204
propricer |
Jun 9 2006, 04:41 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
736conver |
Jun 9 2006, 10:22 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
boxstr |
Jun 9 2006, 10:49 PM
Factory Wheels
Description Construction Size Weight (lbs.) Offset (mm) Backspace (mm) Miscellaneous Mahle "Gas Burners" Pressure cast 5.5x15 9.5 42 ? 901.361.017.00 Fuchs Forged 5.5x14 1? 46 1? 911.361.016.10 4.5x15 1? 42 1? 901.361.012.01 5.5x15 1? 42 1? 901.361.012.04 6x15 12.5 36 121 901.361.012.06 (early); aka the deep dish version* * Early wheel (w/o safety bead) may be lighter) 911.361.020.10 (late) 6x15 11.6 36 121 901.361.012.03 (as fitted on 911R; similar to "06" wheel) 7x15 12 23.3 ? 911.361.020.41 7x15 12 49 (911R) 1145 901.361.012.05; allows larger tire on narrow body 911s 8x15 14 10.6 120 911.361.020.42 / 911.361.020.12 9x15 ? 3.0 127 911.361.020.03 / 911.361.020.06, 11x15 ? 1? ? 911.361.020.05 6x16 17 36 121 911.361.020.43 (early) 911.362.113.00 (late) 7x16 18 23.3 (911) 122 911.361.020.44 (early, 77-84) 911.362.115.00 (late, 85 on) 7x16 23.3 (944) 112 951.362.115.00, add'l clearance for larger calipers 8x16 19 10.6 (911) 112 911.362.117.00 911.361.020.45 8x16 23.3 (944) 135 951.362.117.00; offset compatible for front application 9x16 20 15 130 911.362.119.00; fits rear with SC/RS flares CCLIFUCHSME |
Heeltoe914 |
Jun 10 2006, 09:37 AM
Great info, Thanks see ya in a few weeks.
Lo-Fi Version | Time is now: 18th May 2024 - 09:42 PM |
