need to know some info on swapping 1.7l parts and 2.ol parts, help |
arc914 |
Jun 12 2006, 10:35 PM
Member Group: Members Posts: 139 Joined: 9-April 05 From: Sault Ste Marie,on,Canada Member No.: 3,905 |
hey
does a 1.7l engine fan fit in a 2.ol engine fan shroud with out any issues? and does a 1.7l distributor swap over also? cheers andrew in the Soo |
McMark |
Jun 12 2006, 10:49 PM
No problem on either. You only run into an issue with heads, pistons & cylinders.
brant |
Jun 12 2006, 10:50 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
yes on the fan (although you may need to change or remark the timing spots)
no on the distributor.. (actually it will physically fit, but likely have different advance characteristics) distributors are matched to the system. you need to know your brain # and MPS# to match the whole fuel injection system to each component. brant |
Jun 13 2006, 12:41 PM
The distributor advance curve differences are not that big. There's a "distributor info" page around somewhere--it used to be on the "Renegade 914 Club" website, but that was years ago. I'm not sure where it has gotten to since then.
--DD |
Lo-Fi Version | Time is now: 28th May 2024 - 06:59 AM |
