home stretch, 73 1.7 almost running well |
nycchef |
Jun 13 2006, 07:10 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
have checked or replaced almost entire fuel system. this weekend will adjust valves, replace fuel pump and here's the question... check the throttle valve switch. not much in haynes, some in lash int. but you guys have the best answers how do i do it?
bd1308 |
Jun 13 2006, 07:22 PM
yep. There is a PP article about this...
I assume you are referring to the 4 or 5 pin connector dubbed the Throttle Position Sensor. b |
bd1308 |
Jun 13 2006, 07:23 PM
http://www.pelicanparts.com/techarticles/9...ttle_switch.htm
Maybe this article will get you to the home plate! b |
Pat Garvey |
Jun 13 2006, 07:44 PM
have checked or replaced almost entire fuel system. this weekend will adjust valves, replace fuel pump and here's the question... check the throttle valve switch. not much in haynes, some in lash int. but you guys have the best answers how do i do it? (IMG:style_emoticons/default/beer3.gif) The pelican Parts procedure works well - simple! |
drewvw |
Jun 13 2006, 07:46 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
were the valves way out of wack? Man you are getting close.... (IMG:style_emoticons/default/rocking nana.gif) |
nycchef |
Jun 13 2006, 08:27 PM
guys thank you so much soon i may be driving instead of posting. will let you know
Dr Evil |
Jun 13 2006, 11:55 PM
Awsome!
A TPS wont be too bad if it is messed up. |
turboman808 |
Jun 14 2006, 12:00 AM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Good thing is you will really know your car well by the itme you are done. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 03:44 AM |
