2 Pages V < 1 2
> 911 Speedo transplant for 914 (long), calibrate for your own tire size...
Red-Beard
post Oct 2 2003, 08:55 PM
Post #21
"Ya canna change the laws of Physics"
That looks like it would be fairly easy to fabicate.
JFJ914
post Oct 3 2003, 01:58 PM
Post #22
Well yes and no to James' idea. The "Half Moons" under the cv bolts are hardened steel. This ring will probably be soft sheetmetal and might allow the cv bolts to loosen. Safety wire the bolts??????????
fiid
post Oct 3 2003, 03:08 PM
Post #23
Turbo Megasquirted Subaru Member
Probably better not to mess with the cv joint bolts then. This looks like a stellar idea to me. How much does a 911 speedo go for anyway?? What would be the best way to plug the hole in the back of the tranny?
Fiid.
Qarl
post Oct 3 2003, 07:15 PM
Post #24
Shriveled member
Or consider just getting one of these to convert your speedo cable to a pulse.
http://www.egauges.com/vdo_send.asp?Sender=VW_GM_Cable
Mueller
post Oct 3 2003, 09:48 PM
Post #25
914 Freak!
Hey Karl,
I like that one !!!!
Sorta pricey, but it seems that as long as it's built rugged, it might be more reliable and less prone to damage than a sensor sitting out it the open.
No big deal right now, I just bought a new cable a few months ago (IMG:style_emoticons/default/smile.gif)
Qarl
post Oct 3 2003, 09:50 PM
Post #26
Shriveled member
I'm not sure if this is the same unit that North Hollywood or PA speedo sell. Supposedly they sell a VDO brand adapter specifically designed for this!
fiid
post Oct 6 2003, 12:37 PM
Post #27
well - duh! Good work kellzey! (btw - how is hunter doing?)
I doubt we'd get out the gate with a custom kit for less than a hundred bucks anyway.
Fiid.
ss6
post Oct 6 2003, 01:03 PM
Post #28
fun city...
Karl are you using that VDO adapter? How does it hook up? Do you still need the right angle drive on the tranny?
Qarl
post Oct 6 2003, 03:16 PM
Post #29
Shriveled member
I am not using it. If someone is seriously interested in using it, I would sugest contacting either North Hollywood Speedometer or Palo Alto speedometer.
Regards,
Karl
ThinAir
post Oct 6 2003, 09:02 PM
Post #30
Best friends
I used Karl's approach with a VDO speedo that I got from one of the VW places - The Real Source. All I had to do was to get a local speedo shop to make a short cable to go between the angle drive and the sender. It worked like a charm and was easy to do.
I found it back in their catalog. VDO Programmable Speedometer Kit. Part #309-204 $199.99 www.800luvbugg.com. I think I had to call them to find one in the right size for a 914. The one's in their catalog are smaller so they fit the bug dash.
ss6
post Oct 8 2003, 02:13 PM
Post #31
fun city...
Ernie, you're talking about a mechanical cable, not an electrical one, right?
Wasa914
post Oct 8 2003, 11:47 PM
Post #32
I am still assembling my 914 so my idea is still on the workbench. I am using the VDO electronic speedometer. I purchased a standard GM speedo sender and was pleased to find the mounting thread will fit the 901 angle speedometer cable drive. The sender has a small square key that fits into the GM trans. I had a machinist sodder this square key to the 914 speedometer cable end fitting, a U shaped fitting. Everything fits together and rotates. There might be some long axis play and ware. Hopefully, I can attach a picture of the assembly. The key looks bent in the picture, lense distortion.
Philip
'73 914
Wasa914
post Oct 8 2003, 11:50 PM
Post #33
It wouldn't take my picture.
philip
Brad Roberts
Post #34
914 Freak!
Welcome to the BBS Philip.. we kinda have this place locked down. You have to post 10 times before we allow you to post attachments. You can do this several ways. Start a new thread and post 8 more times and delete the thread.. or wait to respond to 9 more threads.
B
Wasa914
post Oct 9 2003, 12:01 AM
Post #35
Hi Brad,
We met at the Redwood Region PCA meeting. I help out with the region autoX.
This board has greatly increased my 914 knowledge.
PhilipT
2 Pages V < 1 2
- Lo-Fi Version Time is now: 6th July 2025 - 09:13 AM
