'73 stock auxiliary headlamp replacement, How? |
Air_Cooled_Nut |
Oct 1 2003, 04:32 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I got the bumper off the car (easy) to fix the horns (turned out to be a bad relay instead) and replace the bulb in the left side fog (aux. headlamp). Yeah. How do I do it? I saw a screw on the bottom center, removed it and moved the metal tab but the bezel wouldn't come off. Does it rotate or just pop off? Haynes shop manual wasn't much help.
dsmeyer |
Oct 1 2003, 04:38 PM
'73 914 2.0 Group: Members Posts: 134 Joined: 30-September 03 From: West Michigan Member No.: 1,210 |
Just pops... or carefully pry it off with a flat screwdriver.
EdwardBlume |
Oct 1 2003, 08:49 PM
If I remember correctly, the back pops off and then there are two retaining clips around the inside edges. Pay close attention to the clips positions for reassembly. (IMG:style_emoticons/default/beer.gif)
Qarl |
Oct 1 2003, 09:06 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
You don't need to remove the clips to replace the bulb.
Lo-Fi Version | Time is now: 26th May 2024 - 11:07 PM |
