Tires |
Tires |
RonnieJ |
Jun 18 2006, 12:03 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
wondrering if it is possible to put 195-65-15 tire on the stock fuch wheels. Thanks in advance for the info (IMG:style_emoticons/default/smile.gif)
Mueller |
Jun 18 2006, 01:29 AM
yes, I'd go with a 195/60 instead......
hmeeder |
Jun 18 2006, 10:31 AM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
195/65/15 is closer to the original stock tire profile than what most of us are running, so your speedo will be closer to accurate.
I can't remember what the radial equivalent to the original bias-ply size is. For some reason 185/70/15 comes to mind. The taller sidewall will also give you a more compliant ride, if that's what floats your boat. |
rhodyguy |
Jun 18 2006, 10:58 AM
yep. i believe you will get a tab better mpg than the smaller series, 60/50/40. that size will be nice for a long range driver and if your fuch wheels are the real deal (check on the rear of the wheel for a fox head and/or the #914 361 011 01) they should fit nicely. take your center caps off yourself. the tire shop boys will more than likely drive them out with some huge implement, ruining them.
k |
Lo-Fi Version | Time is now: 18th May 2024 - 11:54 AM |
