Dellorto help |
Dellorto help |
1bad914 |
Jun 19 2006, 06:23 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Any body have an old Dellorto carb that they would part out? I have a DRLA 36 that I was rebuilding, a part broke during reassembly, I need this desperatly, it is the part that attaches the accelerator pump to the main shaft, It slide around the shaft and has a screw on the back side. My car is done, I have started it without this piece just to check to make sure it ran, but the acc pump is non op without this part. I tried to JB weld it, but it just snapped off after the first try. I have tried to find a source for it, but CB Performance does not carry it and I don't know where else to go. My only option is to pitch the carbs and buy webers...$$$$!
If you go to this link http://www.cbperformance.com/catalog.asp?ProductID=1245 it is item 7296, they call it a pump contol lever. I know this could have gone in the classified section, but I also need to know if anybody has initial tune specs for this carb, I can tune webers all day, but this is my first set of dels, and they are different. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:11 PM |
