Does DC current run ok in parallel, installing a stereo and amp - finally |
Mike D. |
Jun 20 2006, 03:24 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
After 11 years of 914 ownership I've decided to instal a stereo that I can hear. Yes I know music of the engine, bla bla...
Anyway, I'm no electrician but I was thinking I could take switched on power from the fuse panel and run a power relay (similar to the square one used for hot start) then run a hot from the battery and T off the other side of the relay, one to stereo and one to amp. I'll add fuses on after the T. Does this sound right or should there be 2 relays? what gauge wire should be used for this? this is where the parallel question comes in. Will I be causing problems for something else by stealing power from the hot side of the fuse pannel? |
Lo-Fi Version | Time is now: 18th May 2024 - 09:08 AM |
