Kitcarlson EMS update, Engine Management System Development |
KitCarlson |
Oct 6 2003, 06:14 PM
Member Group: Members Posts: 85 Joined: 20-August 03 From: TN Member No.: 1,052 |
A Status Report:
Things are going well on the EMS development. The hardware has been excellent, no failures, or known limitations. The DIS with user programmable RPM and MAP advance control has worked great! Sensing means has been trouble free. The dual coils have been replaced by one quad terminal coil (a mechanical change for simplicity). There is a tach output to interface directly to a 914 tach. The injection strategy was modified to inject a bank every 2 engine revolutions instead of every revolution. This reduced the injector error at short injector times. Battery voltage compensation for injector open time and dwell are implemented. Starting fuel feature implemented (Cold start valve not required). TPS change (derivative) enrichment implemented (An improvement over throttle switch). Temperature enrichment is implemented. Weather is starting to cool down now for better setup and testing. A case has been designed by volunteer Mark Bland. He is also a 914 owner. He is also designing the sensor interrupter for manufacture. Fuel pump, master relay drive, and stall shut-off impemented Testing on a kitcar with a type3 engine in progress. Runs very well, a great improvement over the carb. Started without hesitation the first try. What a warm feeling! Why type3 instead of 914?, the kitcar tail is removed with 2 bolts, for easy engine access. Type3 is a baby 914. 914 application comming soon. An improved bench simulator, and test set has been developed. A software programmer is developing PC application to dress up the MMI, all setup at the present time with a VT100 terminal emulator running on a Palm® or PC. Setup screens will be posted on my website. I need a Dyno. Any leads on a reasonably priced ones are welcome. Interested in both engine and chassis types. Even consider a tractor dyno, driven by an axle. That's all folks! KitCarlson Please visit http://home.mindspring.com/~dave.c/kitcarlson/ |
Charles Deutsch |
Oct 6 2003, 06:25 PM
Unregistered |
Very cool! Can't wait to see the dyno results including the air/fuel ratio across the entire rpm range.
Mark Henry |
Oct 6 2003, 06:57 PM
Got an estimated cost on it?
Why I ask is because I did the SDS group buy thingy last winter/spring and one thing I learned is that some VW and Porsche people are just a tad thrifty. Lots of tire kickers, few buyers. I'm not trying to discourage you, but this is the reason almost all of your competitors build systems generic to any make of engine. |
Charles Deutsch |
Oct 6 2003, 07:13 PM
Unregistered |
I can buy a Dual 44 IDF Weber Kit for about $600 so I would be willing to pay about $1200 for a well thought out f/i system designed specifically for the 914.
KitCarlson |
Oct 7 2003, 11:25 AM
The system will be affordable. I like to get the most from my money also. The design supports this idea.
There is no reason the EMS cannot be used on other engines. My plans include applications to other engines as time permits. This involves mainly wiring harness work. I will have other options for sensor inputs. The ECU will remain the same. Software will be expanded. My best guess at the moment is a selling price under $1200 for a complete turnkey D-jet upgrade. This price would include EMS unit, wire harness , TPS, quad coil, ignition wires and setup timing sensor. A inexpensive VW distributor may be used as the core. Kitcarlson |
Charles Deutsch |
Oct 7 2003, 11:55 AM
Unregistered |
I love this nuts and bolts, err, transistors and resistors stuff.
redshift |
Oct 7 2003, 06:16 PM
I am interested in replacing my D-jet, yes.
Been keeping an eye out, it's looking very nice, hurry. Post 906, it's getting serious. M |
Air_Cooled_Nut |
Oct 7 2003, 06:29 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
QUOTE(Charles Deutsch @ Oct 6 2003, 05:13 PM) I can buy a Dual 44 IDF Weber Kit for about $600 so I would be willing to pay about $1200 for a well thought out f/i system designed specifically for the 914. Since other units out there run about $1200-$1500 I would be interested in a system that was under $1000. And it would replace those damn Dellorto carbs on my Squareback!!!!!!! I hate carbs...gimme FI any day!! |
JeffBowlsby |
Oct 7 2003, 06:40 PM
914 Wiring Harnesses Group: Members Posts: 8,519 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
One thing to consider about any aftermarket FI...
Daves EMS is more than just a D-Jet replacement, it also has ignition control. Dave, do you intend this to be plug N play, meaning bolt it on out of the box, and the 914-specific programming is either provided in hard copy or already loaded? Aftermarket systems are generic and must be tuned...a major hassle and expense. |
3d914 |
Oct 7 2003, 06:53 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Dave,
This sounds super. I'm currently putting together the MegaSquirt controller as my first attempt to "upgrade" the stock FI. Its been a learning process. By the time I'm finished you should have some good data for the 914. I'd like to be able to compare them. Keep up the good work. |
Qarl |
Oct 7 2003, 07:08 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Has anyone thought about developing a new intake system for larger displacement engines.
The argument always comes up when drying to adapt the DJET system to larger engines like 2270ccs and larger, that the limiting factors for air flow are the inner diameter of the intake runners or the throttle body. People talk about enlarging throttle bodies, but not seeing any real benefit because the runners are too restrictive. One approach is to use individual throttle bodies on a Weber-like manifold such as they do with the CB Performance EFI kit, but then you are faced with making sure all your throttle butterfiles are synched and either individually read or their position read off a common linkage. Couldn't you adapt a larger diameter throttle body from another Bosch equipped car (i.e. Volvo, Rabbit, etc.), and then have larger diameter intake runners and a the plenym box fabbed to mate to the cylinder heads? Then you could adapt larger injectors (that can pump more fuel) and maybe a more aggressive fuel injection compatible cam? Just thinking... |
redshift |
Oct 7 2003, 07:14 PM
(accessory to thread-jacking)
How about billet heads, made to do something a little more? M |
Mueller |
Oct 7 2003, 07:27 PM
I don't see the intake runners or the plenum as being too restrictive with bigger motors and the stock FI, it's more of a combination of the MPS and ECU not being able to be easily tweaked to compensate for the increased demand for more fuel/air. That and most people when going to a bigger engine, use a more aggressive cam, again, the MPS and ECU are not designed for this change.
QUOTE 3d914 wrote: I'd like to be able to compare them. It all comes down to fine tuning, the $100.00 MS can perform just as good as a poorly setup $10k Motec system. My MS ran crappy until I spent time with it on the dyno.... I agree with Jeff, plug-n-play would be best for most people, as long as they have the ability to tweak the system if they need or want to. |
Charles Deutsch |
Oct 7 2003, 07:34 PM
Unregistered |
QUOTE(Air_Cooled_Nut @ Oct 7 2003, 04:29 PM) QUOTE(Charles Deutsch @ Oct 6 2003, 05:13 PM) I can buy a Dual 44 IDF Weber Kit for about $600 so I would be willing to pay about $1200 for a well thought out f/i system designed specifically for the 914. Since other units out there run about $1200-$1500 I would be interested in a system that was under $1000. And it would replace those damn Dellorto carbs on my Squareback!!!!!!! I hate carbs...gimme FI any day!! I'm not aware of any aftermarket f/i systems designed specifically for a 914. The Redline Weber system looks very interesting and could probably be adapted to work. Here's some more info on it. |
seanery |
Oct 7 2003, 07:49 PM
The redline stuff looks pretty good. I like these bodies.
throttle bodies (IMG:http://www.redlineweber.com/SEMA2002/html/image003.jpg) |
seanery |
Oct 7 2003, 07:50 PM
this is the direction I want my teener to take.
Mueller |
Oct 7 2003, 08:03 PM
QUOTE this is the direction I want my teener to take. I think this setup is in the $2500 range (not installed and no dyno time included in that price)...ouch...... |
Charles Deutsch |
Oct 7 2003, 08:08 PM
Unregistered |
Tune it from the passenger seat using a lap top and a g-tech pro. (IMG:style_emoticons/default/wink.gif) I know, it's not the same.
Aaron Cox |
Oct 7 2003, 08:28 PM
anyone use cb performance's Digital fuel injection? what about a modified djet w/ dual throttle bodies?
redshift |
Thanks for that link.
M |
Lo-Fi Version | Time is now: 25th May 2024 - 06:23 PM |
