magaoidh |
Member ![]() ![]() Group: Members Posts: 187 Joined: 28-August 05 From: sydney,australia Member No.: 4,686 ![]() |
I am looking at buying a '73 2 litre(v. nice car) which has a low compression reading in #3 and#4 cylinders.
Any suggestions as to repair of the same? I figure that I will have to drop the engine and pull the heads,strip them down and send the base heads to a specialist. The leakdown results were mainly in the valves,some ring leakage in #4. I will check the bottom end out when I pull the heads. I guess there is no easy fix,I need some advice and clear diagrams about how to go about it. Thanks Geoff |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I'm not sure what diagrams you're looking for, there is a nice engine drop article here on the site (click 914 Info at the top of this page), the Haynes manual will guide you through teardown, or get Jake Raby's video from Bug Me Video or his online store. For the actual work, I would recommend Adrain @ Headflow Masters or Rimco. Get both heads done at the same time.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,184 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
If you are going to pull the heads off the engine you might as well rebuild the motor. You will be half the way there to the rebuild by the time you get the motor out. Also, it will be a good time to check the clutch and that darn $3 shift fork piviot bushing.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Len at HAM is the man at repairing these heads IMHO. Nice work and he replaces all the seats properly so they don't fall out! New guides are a must along with the usual crack repairs between the sparkplug hole and valve seats.
Itsa long way from Aust. but worth fixing right the first time. Definately rebuilt the rest at this time, new rings, bearings, rods reconditioned, and most important a new cam and lifters! (IMG:style_emoticons/default/rocking nana.gif) |
magaoidh |
An exploded parts diagram would help to understand how to.
Thanks so far guys. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,289 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
If money is the reason you are not diving into the bottem end, alot of people here
can relate. You can have the heads rebuilt and re-ring the topend, replace the front and rear seals, oil cooler seals, oil filler gasket, pilot bearing, you get the point. Drive it cool and it should last until you are ready to do the whole thing. |
magaoidh |
You are spot on,thanks mate!
Lo-Fi Version | Time is now: 4th July 2025 - 12:12 AM |
