Carb guru's I need your help, Break out the black magic book I'm stumped |
Joe Ricard |
Jun 28 2006, 05:20 AM
Car has been progressively getting worse.
the problem is off idle stumble. I have to date pulled carbs cleaned out everything. Rechecked and slightly adjusted floats 10mm. Tweaked on accelerator pump linkage (no change). Went down idle jet made it worse 53 to 50. Went up to 55 idle now it sort of covers up the problem but still stumbles. Checked timing Mallory dizzy. bumped it up about a degree (slightly bettter) but still stumbles. 2.0L 86b cam Tangerine 40 IDF's 32mm vents. Runs like a scaulded dog on main jets. Also spent 1/2 hour synching up carb linkage (perfect) off idle. still stumbles. So I am out of tricks. What am I missing. (IMG:style_emoticons/default/blink.gif) Oh yea valves are set good too. good plug wires good plugs. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:26 PM |
